Going with a Stage 2 cam
Old Oct 31, 2015 | 02:52 PM
Seannyc's Avatar
Seannyc
Default Going with a Stage 2 cam
What places do u recommend to order a custom cam
Is comp cams good to order from
Or Texas speed
Old Oct 31, 2015 | 02:58 PM
C7&7's Avatar
C7&7
Or Texas speed
I would consider a cam kit from Texas Speed over just some cam from comp. Texas Speeds would be tried and true in one of their builds with real results. Or maybe give LMR or Vengance a call. Are you gonna do a DOD delete setup? I have one LMRs smaller non DOD delete blower cams in my car and love it.
Old Oct 31, 2015 | 03:58 PM
Seannyc's Avatar
Seannyc
Yes I was thinkin dod delete I'm goin with a cam for a supercharger u think a dod delete is nessasary
Old Oct 31, 2015 | 04:12 PM
C7&7's Avatar
C7&7
If you're looking for all out top end power and willing to lose some drive ability then a DOD delete cam gets you there. I just wanted something that was blower friendly and gave me the larger fuel lobe ... & of course some chop. I think non DOD delete cams fit supercharged applications better.
Old Oct 31, 2015 | 04:34 PM
Seannyc's Avatar
Seannyc
How much did the cam give u to the wheels
Also in there a noticeable sound difference i want a chop sound and like 50whp would a non dod give me that or would i have to get dod delete
Old Oct 31, 2015 | 04:37 PM
MikeLsx's Avatar
MikeLsx
I would delete all that gas savings crap no matter what can you go with. Just another thing that can fail.
Old Oct 31, 2015 | 04:40 PM
C7&7's Avatar
C7&7
I picked up 70 to the tire with a cam and meth.
Old Oct 31, 2015 | 04:45 PM
ilivas's Avatar
ilivas
You would obviously be better off going with a custom cam. Especially if you do head work or a blower. But the off the shelf cams do work well, just not as well as a custom. There is a difference between NA cams and blower cams so keep that in mind. If I were to do it again, I'd get it custom spec cam for my my blower setup.
Optimally, you would want one that deletes the DOD.
Also, I went with the TSP VVT3. It's very street able. No issues at all other than a hit in gas mileage.
Old Oct 31, 2015 | 09:22 PM
RussM05's Avatar
RussM05
Who else grinds cams other than Comp Cam? They advertise 3 cams. Is it any coincidence shops are showing 3 cams? I think most shops are reselling Comp Cams off-the-shelf. That ok I guess.
Old Nov 1, 2015 | 12:00 AM
ilivas's Avatar
ilivas
Any good reputable shop can custom spec you a cam for your setup.
Old Nov 1, 2015 | 02:09 AM
BooSSted's Avatar
BooSSted
Cam motion
Old Nov 1, 2015 | 04:36 AM
Seannyc's Avatar
Seannyc
So u say bout 40 to 50' to the wheel without met and how is the sound compare to stock at idle and WOT
Old Nov 1, 2015 | 04:46 AM
Seannyc's Avatar
Seannyc
Thanks for the info how was ur gains wit the cam Im differently getting a custom cam I just don't want no 20 30whp I want at least 45 55whp and I don't no what to go with none dod delete or dod delete lotta shops I call spect me to no the defferants don't explain to me right
That's why I'm on here lol
If i do go dod delete is that also afm delete if not how do i go from there
The cam I'm tryin to go with is for a supercharger but not adding the supercharger till next summer cam first
Old Nov 1, 2015 | 08:15 AM
RussM05's Avatar
RussM05
AFM= Active Fuel Managemet is Displacement on Demand. Same thing.
The best way to delete the AFM is replace the hardware including the new lifters and disable in the tune. New lifters requires taking the heads off. If you do that, you might as well get the heads CNC ported ar the same time.
While you could get some power with a cam intended to be used with a supercharger, paying for installation now then next year doing. A super charger will cost more. You will need to pay fir a tune with the cam then pay for another tune with the super charger.
Doing mods is a slippery slope.....$$$$
Old Nov 1, 2015 | 11:18 AM
C7&7's Avatar
C7&7
Here you guy bud. Here is an idol clip. You can barely tell the cam is there driving around.
Old Nov 1, 2015 | 12:55 PM
Seannyc's Avatar
Seannyc
Nice sounds good is that on warm up or cold start
Old Nov 1, 2015 | 12:56 PM
Seannyc's Avatar
Seannyc
An extra 6 700$ is not a problem i just wanna make sure the cam comes out right
To Going with a Stage 2 cam
Old Nov 1, 2015 | 01:00 PM
C7&7's Avatar
C7&7
It was warm. Maybe 5-10 minutes after I started it.
Old Nov 1, 2015 | 01:58 PM
Seannyc's Avatar
Seannyc
What was your lift and duration
Old Nov 1, 2015 | 02:12 PM
ilivas's Avatar
ilivas
With the addition of headers and cam, I picked up 120whp on pump gas. It could of been much more with meth.
I would go with the most aggressive off the shelf cam you can get if you end up going that route. The TSP cam package I bought included the AFM delete kit in the package. You also want the fuel lobe.
