Tapping forward fuse box for power
Old Nov 1, 2015 | 02:10 PM
rettop's Avatar
rettop
Default Tapping forward fuse box for power
I recently added a device to my Z51. I needed power on when the engine was running but otherwise off. Perhaps my findings may be of some help to others in the future.
C7 CorvetteEngine Compartment Fuse Box
Listed below are some of the easily accessible fuses that can be “tapped” easily withan add on fuse tap device generally available.
Only those with no voltage with the engine off are listed.
Those with an “X” after them have normal ~12 volt DC voltage when the engine isrunning.
15X 14 19 28X
27X 30X 31X 32X
42X 36X 41 34
52 39X 40X 33
38
Last edited by rettop; Nov 5, 2015 at 11:18 AM. Reason: File didn't upload correctly - fixed it.
Old Nov 2, 2015 | 10:56 PM
meyerweb's Avatar
meyerweb
Thanks. Out of curiosity, what voltage do the one's without an X provide (if you made note of that)?
Old Nov 2, 2015 | 11:19 PM
rettop's Avatar
rettop
I did not record that voltage. Sorry.
Robert
Old Nov 4, 2015 | 11:44 PM
BOBSZ857's Avatar
BOBSZ857
Listedbelow are some of the easily accessible fuses that can be “tapped” easily withan add on fuse tap device generally available.
15X 14 19 28X
27X 30X 31X 32X
42X 36X 41 34
52 39X 40X 33
38
Thanks for saving me the trouble of figuring this out on my own.
Old Nov 5, 2015 | 08:53 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
To be clear, the Fuse numbers with the X have switched 12v, correct?
Elmer
Old Nov 5, 2015 | 11:07 AM
rettop's Avatar
rettop
Elmer
That is correct Elmer. Engine off = no power. Engine on = power.
Old Nov 5, 2015 | 11:22 AM
rettop's Avatar
rettop
The fuse numbers posted are for my 2015 Z51 Coupe.
To Tapping forward fuse box for power
