Splash Guards
Old Nov 28, 2015 | 11:25 AM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Default Splash Guards
I have the f & r factory accessory splash guards for the '16 I am picking up at B G before Christmas. I have both a ratcheting 7mm box wrench and 6 pt short 1/4" drive socket w/ ratchet I can tote along. Once I remove the 7mm screw at the bottom of the O E trim, how difficult is it to pop the clips loose from the body that run alongside the moulding ? Tia, Mike
Old Nov 28, 2015 | 12:08 PM
juanvaldez's Avatar
juanvaldez
Once the screw is out it is very easy. I had some trim tools I bought for the job that I didn't even use. You can see which screw to remove using the replacement splash guards as a guide.
Old Nov 28, 2015 | 12:14 PM
savage's Avatar
savage
I have used the same ones for my 14,15 and now 2016. Just pull from the bottom and use your fingers not a tool that can hurt paint as each one of the tabs need a little force to pull out. F.Y.l there is two others screws next to the one you need to take out, it's the one closest to outside of car but it hurts nothing if you don't find the right one at first.
Old Nov 28, 2015 | 12:20 PM
Bucknut2006's Avatar
Bucknut2006
Took me more time to locate my tools than swap them out. Popped out easily with my fingers.
Old Nov 28, 2015 | 12:24 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Cool ! I thank y'all. I will bring my multi tool from Harley Davidson too just incase. Time to think like a boy scout again ...............
Old Nov 28, 2015 | 12:30 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
That's why I have them sitting on the desk in the den. Next to that is a small zip bag to carry them in. In fact, I'm going to pack them now while I think of it.
To Splash Guards
