Help-Recomendations
Old Nov 30, 2015 | 09:04 PM
GPASZO6's Avatar
GPASZO6
Default Help-Recomendations
Hello Everyone, need your help. I lowered my 2014 Coupe on stock bolts stock tires with a set of Varro Wheels (Gerry) and the fender gap still seems to wide. Can you provide me some insight as to what tire sizes with combo stock/aftermarket bolt set ups your using? My plans are to keep the stock bolts and replace the stock tires with 305/30 and 265/35. Will this work for me?
Thanks for your help
Juan
Old Dec 1, 2015 | 12:55 AM
HANNY's Avatar
HANNY
cant speak to your tire size you just need to spec out the demisions and get you height and width off that.
The stock bolts you get about one inch in the front gap and the back you can go a little less then that (but that's ghey because they wouldn't match)
If you are looking for less gap then get aftermarket bolts for around 50 bucks and "job done"
