2014 Z51 replacement non runflat tires.
Old Dec 16, 2015 | 08:21 PM
VRMMMM's Avatar
VRMMMM
Default 2014 Z51 replacement non runflat tires.
This might not be the right place to post this, but I need to replace the tires on my 2014 Z51 C7. I want to replace with non run flat tires. I would like a performance tire that will last like 20-25k miles. Any recommendations?
Thank you in advance.
Old Dec 16, 2015 | 09:16 PM
EcoBrick Bob's Avatar
EcoBrick Bob
Dazed Confused & Verklemp
I haven't changed out my Z51 tires yet, but I run Pilot Super Sport non-run flats on my other 3 vehicles. They are the best handling tires I have had on any vehicle. On my EcoBoost Flex, I got over 30,000 miles on a set vs about the same mileage on a set of Conti DW's. The PSS handled much better than the DW's, but when it gets below 50 they start to loose traction as the tread rubber starts to get harder.
None of my vehicles run summer tires when it's below freezing.
On my 2 G8 GT's, the PSS definitely handle better than the original Bridgestone O50A's. The fronts on those lasted forever, but the rears were only good for about 12K. Wonder why??? HAHAHA But... it was definitely fun!!!!
My plan is to go with PSS non- run flats either when I get a second set of wheels, or when my original run flats need replacement.
Old Dec 17, 2015 | 05:45 PM
Chets LS3's Avatar
Chets LS3
I just got in a set of 295/255 non run flats MPSS for my replacements.
Old Dec 20, 2015 | 02:47 AM
officermartinez's Avatar
officermartinez
Originally Posted by officermartinez
We went with the factory tire offerings.. Michelin PSS's (but they are the NON run flats). 255 35 19's front, 295 30 20's rear and purchased (4) new GM OEM TPMS sensors.
https://www.corvetteforum.com/forums...post1591114570
To 2014 Z51 replacement non runflat tires.
