Called the dealer today to order a passenger side half shaft to install on the drivers side since it's a bit larger. Roughly $300 which is fine but, according to the dealership, there is a first design and a second design. Does anyone know if the second design is an upgrade or just an insignificant difference? If any improvement has been made, I'd like to know about it.
Are you worried about more wheel hop going to equal diameter shafts?
No. The only time I accelerate that hard from a stand still is at the drag strip with drag tires. The burnout in the water box would be the only time it would be possible. If it wheel hops then, I'll let off and try plan b.
My DR's aren't in yet, but are you saying that wheel hop is greatly reduced? I will be on 18" rims.
Wheel hop won't happen in a dead hook. It never has with me anyway. Hopefully your drag radials will eliminate any tire spin. 18's are a smart decision. Gives you a ton of options and just a little more sidewall.
I just finished messing around with shafts ,i was bored...and the c6 shaft does fit into the c7 diff ...the only thing different is the tip of the shaft for the hub is to small..but i know the c7 is bigger.hmmmm i wonder.....they are avout the same length. ..i just had to try...
The c7's being hollow is more of a problem than the overall size. Thanks for the info.
