Dumb Question NPP
Old Dec 21, 2015 | 07:23 PM
Black Snake's Avatar
Black Snake
Default Dumb Question NPP
Just got a 2014 Z51, lightly used and very clean...trying to figure out if it has NPP or dual mode exhaust....I am on the infotainment center, that is where you can check the off check correct? It is like I cant click or "unclick" this button, does that mean I dont have it......I know I know you ask well does it sound diff dummy? It doesnt at idle but I think it may on acceleration. I though it would be more noticable
Is there a better way to determine if this car has NPP, dealer was no help LOL
Old Dec 21, 2015 | 07:28 PM
1Bridog's Avatar
1Bridog
Look at the exhaust...go to the back of the cat and look for the valves on the sides of exhaust just behind the tips...
1Bridog's Avatar
1Bridog
..car...not car. Sorry
Old Dec 21, 2015 | 11:03 PM
owc6's Avatar
owc6
If you look back there, and it farts in your face, it's a cat not a car.
Old Dec 22, 2015 | 11:47 AM
StingerBG's Avatar
StingerBG
Also....you should hear a very noticeable difference in tone just at idle. At least I can on my car. The difference in tone is between touring and sport mode (ie weather, eco and touring have the valves closed, and sport and track have them open). It takes about 1-2 seconds for the valves to open/close after changing the mode. Did they not have the original window sticker? I always keep mine, or ask for it when purchasing a vehicle...helps on resale.
Old Dec 22, 2015 | 01:03 PM
Bucknut2006's Avatar
Bucknut2006
Car has to be in run mode to change the NPP settings.
Also, you should see the flaps in the outer pipers along with the black plastic actuators on the side.
Old Dec 22, 2015 | 03:54 PM
joemosfet's Avatar
joemosfet
NPP Dual Mode Exhaust has four equally spaced exhaust tips. Regular exhaust has smaller exhaust tips with a noticeable gap between the middle two tips.
Old Dec 28, 2015 | 09:09 PM
hisvett's Avatar
hisvett
St. Jude Donor '14-'15
OR you could just lift the rear carpet just inside the rear hatch and check the RPO tag for "NPP" .....4 down - 4 across on my GS, yours will probably be different
Old Dec 29, 2015 | 04:10 PM
Zymurgy's Avatar
Zymurgy
Moderator
Look at the exhaust just before the tips. If there are valves on the two outer ones, you have NPP. No valves, no NPP.</p><p>Here's some photos of the NPP (and&nbsp;AFM) valves. The AFM valves are before the mufflers and the NPP are the valves after the muffler - right before the exhaust tip:</p><p><img alt="" src="http://img.photobucket.com/albums/v610/talon_90th/NCM%20Bash%202013/DSC_0970_zpsfc957f23.jpg" /> <img alt="" src="http://img.photobucket.com/albums/v610/talon_90th/NCM%20Bash%202013/DSC_0968_zpsf5bb010d.jpg" /></p><p>The NPP valve opens up a less restrictive path through the muffler that results in less back-pressure, more HP and torque and a louder exhaust sound.</p><p>The non-NPP exhaust has the AFM valve and only a single outlet pipe from the muffler that the splits into the 4 exhaust tips. No NPP valve.</p>
Old Aug 9, 2020 | 04:11 PM
teds56's Avatar
teds56
Do you know if it's possible to retrofit a NPP system on a 2014 3LT Stingray that never had it?
To Dumb Question NPP
