Disable fuel system for compression test?
Old Dec 27, 2015 | 11:08 AM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Default Disable fuel system for compression test?
Curious what the proper way to disable the fuel system is for doing an engine compression test. I already have the ignition system disabled by disconnecting the coil packs but not sure about fuel system. I assume I would pull the fuel pump relay and then run it till it shuts off? I have the service manual but it advises that you must put the car into compression test mode with a scan tool (not an option for me). Surely disabling the fuel and spark is sufficient enough. Thoughts on correct fuel system disabling procedure?
Ant
Old Dec 27, 2015 | 03:07 PM
meyerweb's Avatar
meyerweb
I'd pull the fuse pump fuse or relay, if it were me.
Old Dec 27, 2015 | 08:48 PM
C7&7's Avatar
C7&7
Yea I would pull all the coils and the fuel pump relay.
Old Dec 28, 2015 | 10:13 AM
officermartinez's Avatar
officermartinez
Did you finish your compression testing yesterday? Any updates?
Old Dec 28, 2015 | 05:50 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
I didn't get to do it actually. I got caught up working on repairing my daily driver. Can only afford to have one car not drivable at a time lol. I'm still at work now so likely won't be able to do it tonight either. My new plug wires will be in either tomorrow or Wednesday though so I don't have everything to finish it up today anyway. Don't worry.. as soon as there are updates the forum is the first to know!! LOL
Old Dec 29, 2015 | 05:59 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Ok I have found two fuses related to fuel (no relays). In the front fuse box is fuse number 31 (10A), which is listed as the " Fuel Pump Driver Control Module". This is abbreviated on the fuse box diagram under the lid as "FPPM"
In the back fuse box (in trunk) there is fuse 30 (25A) which is also listed as the "Fuel Pump Driver Control Module". This is abbreviated on the rear fuse lid as "FUEL PUMP PWR MDL".
I assume pulling both of these fuses should be good enough to stop fuel flow and not damage anything right?
Old Dec 31, 2015 | 11:42 AM
Dave01GT's Avatar
Dave01GT
I pulled both fuel pump power fuses yesterday and when I went to crank mine to get it into Neutral, it didn't spit out any fuel.
Old Dec 31, 2015 | 11:46 AM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Yep I confirmed late last night the same thing.
Old Dec 31, 2015 | 12:04 PM
Dave01GT's Avatar
Dave01GT
Is yours an auto or stick? If auto, is there a way to get into neutral without having it crank?
Old Dec 31, 2015 | 01:36 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Mine is a stick. I do believe there is a fuse for the lockout though just dont know which one..
Old Dec 31, 2015 | 03:30 PM
imxz28's Avatar
imxz28
Don't know if this is a poor idea but you could always hard wire your starter motor and bump it 4 or 6 revolutions with a spare battery. If you give this more thought, I'd remove all plugs for less drain on the starter/battery.
Old Dec 31, 2015 | 06:08 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
I pulled all plugs already so no worries there. Pulling both those fuses did the trick
Old Dec 31, 2015 | 08:37 PM
T/A KID's Avatar
T/A KID
Glad you figured it out brother
To Disable fuel system for compression test?
