Saccitycorvette Fangs
Old Jan 2, 2016 | 12:26 PM
juanvaldez's Avatar
juanvaldez
Default Saccitycorvette Fangs
Bought the Fangs while they were on sale, quality product. I watched the installation video and bought the little vibrator detail sander at Walmart for under $20. It took about and hour. Car needs to be on ramps or stands to get access.
The supports have a weep hole in them. So do the fangs. When you glue them on the glue expands and oozes out of the holes blocking them. It is probably a good idea to open them back up with a drill bit while you are under there.
Two thumbs up for a quality product. I haven't dragged yet but there is always a first time. Cheap insurance with little/no downside.
Old Jan 3, 2016 | 12:30 AM
dovervold's Avatar
dovervold
Fangs??? And expanding and oozing glue??? Cheap insurance??? What you say...
Old Jan 3, 2016 | 01:11 AM
fleming23's Avatar
fleming23
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
I assume the OP is talking about adding front skid plates protectors under the radiator support. Sounds as though they glue on in that particular application.
Old Jan 3, 2016 | 07:36 AM
juanvaldez's Avatar
juanvaldez
The radiator supports are made of aluminum and are the lowest part in the front of the car, first hard part to scrape. Glue seems appropriate as glue is used in much of Corvette construction.
Old Jan 3, 2016 | 09:43 AM
meyerweb's Avatar
meyerweb
The glue used is Gorilla Glue, and is an appropriate method for attaching plastic to metal.
These are the "fangs" in question:
http://www.saccitycorvette.com/C7Fangs.html
And here's a good DIY install how-to that shows how they're attached:
http://netwelding.com/Skid_Pad_Protector.pdf
Old Jan 3, 2016 | 10:31 AM
dovervold's Avatar
dovervold
Got it, looks like a good idea. Suprising that GM would leave aluminum exposed in this area...
Old Jan 4, 2016 | 12:48 AM
HANNY's Avatar
HANNY
on my C6 I think they would work great, but on my 7 not sure it will do much (I could be wrog there just need some real world opinions. I have the front skid and even with it on wouldn't the front spoiler hit before those? someone PM me with your thots and ill get a pair stat. take care, paul
Old Jan 4, 2016 | 08:35 AM
juanvaldez's Avatar
juanvaldez
I think it will depend on the type of obstacle. On a speed bump or something like a parking space curb thingy they will work.
The drill bit size that fits the fang hole is 1/8". When I ran a drill bit in the hole to clean out the glue I got a ton of water out.
Old Jan 6, 2016 | 05:34 PM
meyerweb's Avatar
meyerweb
I've scraped my fangs once. Went over a speed bump higher than I realized, and when the suspension compressed after coming off the bump the radiator mounts scraped. And I think that if you pulled way to far over a curb you could hit those mounts, even if you tore up the spoiler first. You'd probably have to be going way too fast to do that, but things happen.
Cheap insurance.
Old Jan 7, 2016 | 08:31 AM
Walt White Coupe's Avatar
Walt White Coupe
A waste of time and money.
Old Jan 7, 2016 | 09:11 AM
juanvaldez's Avatar
juanvaldez
So true! I could have got neon or mudflaps.
Old Jan 7, 2016 | 09:25 AM
Stingray Al's Avatar
Stingray Al
I agree. The skid plate is designed to contact the pavement.
Old Jan 7, 2016 | 08:18 PM
meyerweb's Avatar
meyerweb
It's not a "skid plate." GM has no part in their parts list with that name. What people call a skid plate are the aluminum lower radiator mounts. They're designed to hold the radiator, not protect the car when it hits the pavement.
To Saccitycorvette Fangs
