Engine light issue
Old Jan 7, 2016 | 09:43 PM
rgreenwood's Avatar
rgreenwood
Default Engine light issue
Engine light came on at 200 miles 2016 vehicle contacted ONSTAR who advised the problem was code P300. Took to dealer replaced spark plug wire. Two weeks later engine comes on twice just blinking for about 5-10 seconds each time during one drive. Took back to dealer and they say can't find an issue because shows no light every came on??
Old Jan 7, 2016 | 09:51 PM
robert miller's Avatar
robert miller
Default ttt
Look at the ne plug wire again. For some reason it is getting loose are low volts from that plug wire r spark plus are coil. Number of problems on this from guys in here.
Old Jan 7, 2016 | 10:22 PM
rgreenwood's Avatar
rgreenwood
. Thank you. Sounds like a good solution. Take care
Old Jan 8, 2016 | 01:06 PM
06MonteSS's Avatar
06MonteSS
Supporting Vendor
multiple misfire code.. check plugs, wires, coils, clean the MAF sensor.. check the plugs for cracked ceramic insulator - that could cause it too..
Old Jan 8, 2016 | 03:04 PM
rgreenwood's Avatar
rgreenwood
Thanks. Will take back to dealer
To Engine light issue
