Getting ready for my build setup in June-adding cam
Old Jan 10, 2016 | 06:42 PM
Seannyc's Avatar
Seannyc
Default Getting ready for my build setup in June-adding cam
Going custom Blower Cam 30% fuel lobe LT headers
green filter and E85
How Much Whp yous think I'll get with and without the E85
Old Jan 10, 2016 | 11:54 PM
C7&7's Avatar
C7&7
What kind of cam? Dod delete? Kinda matters if you want to know how much power you may pick up.
Old Jan 11, 2016 | 12:53 AM
Seannyc's Avatar
Seannyc
Sorry Dod delete
Old Jan 11, 2016 | 05:23 AM
kiley2418's Avatar
kiley2418
Not sure what tranny is in your car? But for m7 and if it's a true spec'd "blower cam" I'd say 520-530rwhp range.
Old Jan 11, 2016 | 08:19 AM
Seannyc's Avatar
Seannyc
M7 what u think without the e85 490 to 510whp
Old Jan 11, 2016 | 08:56 AM
Elite275's Avatar
Elite275
I think you may creep close to 500 for sure.
I'm a hair over 550rwhp on my setup with a couple more bolt ons and heads than what you have listed above. I'm also running E85.
I have:
FlexFuel Sensor
TSP LT's no cats
Stock ported intake manifold
VMax ported TB
aFe cold air intake
Vengeance Heads
Vengeance Stage II cam
Vengeance Tuned
To give you an idea on fueling when Vengeance tuned my car and I had a little E85 in there mixed with mostly 93 it had 27% ethanol and produced 527rwhp. They then added pump E85 which was low in ethanol down there and with 62% ethanol it hit 542rwhp. I can't remember the exact number but on a dyno day locally with 79% ethanol it was slightly over 550. In the summer off the pump I can stay around 80-82% ethanol and she runs great. For the heck of it this summer I plan to put some VP Racing C85 in there and see what the dyno yields even though it's too costly to run all the time. A buddy has a car that is dedicated to E85 and runs this so I can get it to try without breaking the bank.
Old Jan 11, 2016 | 09:24 AM
C7&7's Avatar
C7&7
Yea I was gonna say like 480-500 without e85. If the cam is real radical you might throw down some big numbers.
Old Jan 11, 2016 | 12:43 PM
Seannyc's Avatar
Seannyc
I have:
FlexFuel Sensor
TSP LT's no cats
VMax ported TB
aFe cold air intake
Vengeance Heads
Vengeance Tuned
Great numbers Did you have to add. A fuel pump ?
Old Jan 11, 2016 | 02:41 PM
Elite275's Avatar
Elite275
No, I'm still stock LT1 fuel pump and injectors. If I do anything else I have to step up to the LT4 components.
Old Jan 11, 2016 | 08:35 PM
Seannyc's Avatar
Seannyc
If u add the s/c with the cam and don't run e85 would u still have to add a fuel pump I see people getting 700whp on stock pump dunno how true
Old Jan 11, 2016 | 11:55 PM
C7&7's Avatar
C7&7
Adding the cam with larger fuel lobe gets you where you need to be. Meth is also usually added as well. However the cam is good.
Old Jan 12, 2016 | 01:57 AM
Seannyc's Avatar
Seannyc
Ok thx
Old Jan 12, 2016 | 08:24 AM
Elite275's Avatar
Elite275
I agree. I think I could probably get by with the SC and running 93, but it seems like most add meth as a precaution. My cam does have the 32% fuel lobe.
Old Jan 12, 2016 | 01:51 PM
Seannyc's Avatar
Seannyc
How's your tsp headers sound in person
Also was the portin intake manifold and throttle body worth the money
Old Jan 12, 2016 | 02:51 PM
Elite275's Avatar
Elite275
TSB headers sound fantastic. WOT they scream. I've only heard them catless though as the emissions aren't rigorous where I'm at so all cars that I've heard with them have foregone the cats. I've had ARH and Kooks before and I'm just as satisfied with these.
Ported intake manifold - YES. Ported TB - No. Just my perspective. I added the TB when I was doing all bolt on stuff and just wanted to play with the car. Now that I've done more and will probably continue modding for more power I'd skip it if I had it to do over again. Could just be the TB I'm using though (VMAX). I've heard several others with issues (Higgs has one and I don't believe he's had any issues though). I had one on my C6 as well and it was fine.
Old Jan 12, 2016 | 04:38 PM
Seannyc's Avatar
Seannyc
Ok good to know I'm goin with a cam so will the throttle body be nessasary
And what throttle body does Higgs have
I'm just tryin to get everything that is compatible wit the supercharger and that will benefit the s/c and cam
Old Jan 13, 2016 | 07:55 AM
Elite275's Avatar
Elite275
I believe Higgs has the same VMAX as I do, but doesn't have any issues. These are supposed to be CNC ported and all the same but it seems like different folks are getting different results. If you want a ported TB I'd consider the new Katech at the top of the list or WeaponX.
With or without the TB it will be negligible either way with the mods you're planning. Once you get that SC and cam in there it will be a blast to drive and TONS of power! Keep us updated on the build.
To Getting ready for my build setup in June-adding cam
Old Jan 13, 2016 | 08:06 AM
Seannyc's Avatar
Seannyc
Okay Probley will go katech and I wil keep yous updated thx
Old Jan 13, 2016 | 10:22 AM
Higgs Boson's Avatar
Higgs Boson
I had a Vmax on my silverado and it had surging issues I could not tune out so I traded it in.
My C7 has a WeaponX ported TB and no issues at all. I do have a ported intake but I forgot where I got it...maybe Formato?
Old Jan 13, 2016 | 01:26 PM
Seannyc's Avatar
Seannyc
What's the better way to go intake or throttle body
I might go with katech throttle body
