Breather fume relocation
Old Jan 12, 2016 | 03:17 PM
C7&7's Avatar
C7&7
Default Breather fume relocation
Anyone that has done the breather fume relocation to under the car (LMR's kit), did you guys put filters on the end of the lines? I am in the process of re-routing mine from my lashway motorsports can and was kicking around the idea of putting filters on the ends just because I am antsy about having open lines.
Any issues with pressure if you did do filters?
Old Jan 12, 2016 | 06:15 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
I have the LMR breather (updated revision) with my lines run down to the inside of the front drivers side of the bumper. I have installed an Airaid filter on each of the lines. Havent seen any pressure issues.
Old Jan 12, 2016 | 06:46 PM
Mike02z's Avatar
Mike02z
I have the FSP and yes, it comes with 2 filters on the output of the breather. They look like mini K&N filters.
Old Jan 12, 2016 | 07:19 PM
C7&7's Avatar
C7&7
With half inch hose?
Old Jan 12, 2016 | 07:20 PM
C7&7's Avatar
C7&7
Any pics to share of the filters? Half inch hose inlets?
Old Jan 12, 2016 | 07:47 PM
Mike02z's Avatar
Mike02z
Not sure but they may be 5/8". I'm not home to verify. Here is mine after initial install.
Old Jan 12, 2016 | 07:58 PM
C7&7's Avatar
C7&7
That looks like -10 AN fittings with 1/2 inner diameter heater hose? Similar to what I'm gonna do. Any pics of the filters on the evacuation ends?
Old Jan 12, 2016 | 08:31 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Airaid filter model number 770-137. 1" inner diameter (yes, one inch) 2" outer diameter. Don't have any pics though..
Ant
Old Jan 12, 2016 | 08:45 PM
Mike02z's Avatar
Mike02z
From the FSP web page...
Old Jan 12, 2016 | 10:06 PM
DoubleDown's Avatar
DoubleDown
Please post pictures when it is complete. I also have the Lashway catch can and have been wanting to relocate the breather filters.
Thanks.
Old Jan 12, 2016 | 10:10 PM
C7&7's Avatar
C7&7
Thanks.
No problem. Will have it done this weekend. Had some custom adapters made for the can to adapt -10AN lines. I will do a write up when I'm done.
Old Jan 13, 2016 | 03:36 PM
Mike02z's Avatar
Mike02z
AN fittings were an option with the FSP breather/catch can but then you need to weld bungs to the valve covers so the AN fitting will connect. I went with Push Lock fittings.
Old Jan 16, 2016 | 07:21 PM
C7&7's Avatar
C7&7
Thanks.
Finally finished my lashway re-route. Here is my write up:
https://www.corvetteforum.com/forums...post1591338211
To Breather fume relocation
