Stuck brake piston
Old Jan 26, 2016 | 09:21 PM
Chets LS3's Avatar
Chets LS3
Default Stuck brake piston
Well, I was changing the pads to a new set of track pads. Pressed in pistons with old pads like always. pushed in bottom pistons (top piston pushed out some) went to push in top piston and nothing. Long story short after cracking bleeder, opening bleeder to now pulling the caliper.
With caliper disconnected no budge.
I have pics attached, and I don't know much about seals, but these things look horrible.
3000 miles. one track weekend. One set of carbotech pads.
Old Jan 27, 2016 | 07:32 AM
nytrorcr's Avatar
nytrorcr
Hope that assy isn't as bad as it looks. I would reassemble and pressurize system and see if that allows piston to free up. Maybe warrenty time..........
Old Jan 27, 2016 | 08:43 AM
Chets LS3's Avatar
Chets LS3
Well I ended up disconnecting the entire caliper. I was able to turn the piston back and fourth. After that it slid right back in
Old Jan 27, 2016 | 04:56 PM
Bill Dearborn's Avatar
Bill Dearborn
Can't really tell anything by the condition of the dust boots. They turn into crispy critters shortly after the car gets to a track where the brakes can be exercised properly.
Bill
Old Jan 28, 2016 | 11:38 AM
bob guzzy's Avatar
bob guzzy
You may have overheated the caliper and cooked the boot and seal to the piston or warped the piston.
Either way I think your going to want to put at least 1 new piston in.
To Stuck brake piston
