Anyone Seen This: Power Steering Flutter
Old Feb 9, 2016 | 12:25 AM
Jet Vet's Avatar
Jet Vet
St. Jude Donor '15-'16
Default Anyone Seen This: Power Steering Flutter
I had my 2015 Z51 on the alignment rack at my local speed shop last week to do some troubleshooting on a very slight pull to the right. All alignment settings were correct, so one of the owner's expert friends recommended jacking the front wheels up and turning the wheel slowly lock to lock with the engine running. When we did that, a light vibration could be felt in the steering wheel at two distinct places. The real shocker was that during those two light vibrations, the front wheels exhibited a dramatic fluttering, vibrating noticeably. I brought it to the dealer and they did the same test with the same result. I track the car, and don't feel any steering vibration either there or on the street. The dealer wants to see if other C7's do the same thing before deciding how to proceed. Has anyone ever seen this? If any of you have your front end jacked up soon, and can turn the steering wheel slowly lock to lock with the engine running before removing the wheels, please let me know if anything like what I described shows up. Thanks.
JV
Old Feb 9, 2016 | 01:42 PM
subfloor@centurytrans's Avatar
Supporting Vendor
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
JV
Does you car have Magnetic Ride Control? If it does, see if the car pulls to the right in Sport or Track Mode but not in Touring. If it doesn't pull in Touring then you may need a new power steering rack as I had a similar problem on my 2015 Z06.
Old Feb 9, 2016 | 02:17 PM
Jet Vet's Avatar
Jet Vet
No, I didn't get the MRC option. We also tried revving the engine with the front wheels off the ground and the steering wheel straight ahead to see if the steering would pull to the right on its own, which would indicate a problem with the electric power assist, but that didn't happen. We just happened to notice this vibration problem while doing that test.
JV
Old Feb 15, 2016 | 08:27 AM
jedblanks's Avatar
jedblanks
There is software that runs the electric power steering that runs algorithms to do things like eliminate smooth road shake when going around a long sweeping flat curve.
Maybe the software or hardware that runs this has a glitch on your car (or on many cars)
Old Feb 15, 2016 | 08:54 AM
NSC5's Avatar
NSC5
It is also possible this is just an artifact of the control software that shows up with no load on the steering system. The smoothing software is mentioned briefly in this video which was released when the C7 first hit the streets:
Old Feb 15, 2016 | 11:46 AM
meyerweb's Avatar
meyerweb
That's what I was about to write. The OP is operating the power steering system outside its normal operating parameters, so it's hard to know if it's really a problem.
Old Feb 15, 2016 | 02:22 PM
Jet Vet's Avatar
Jet Vet
Also my thoughts. I plan to ask GM what they think.
JV
To Anyone Seen This: Power Steering Flutter
