Help to wire a shift light
Old Feb 16, 2016 | 08:15 PM
BJ67's Avatar
BJ67
Default Help to wire a shift light
I am considering buying and installing a name brand shift light . Does anyone know what wire I can hook into to get a signal. I have a 15 M7 car and occasionally take it down the 1/4 and want to dial in my shift points and be the consistant on all 3 shifts.
Old Feb 17, 2016 | 02:03 AM
Little Red Corvette1's Avatar
2016 C7 of the Year Finalist
Default Shift Lights
My 2014 M7 has shift lights from the factory. They are on the top of the screen.
Old Feb 17, 2016 | 08:49 AM
BJ67's Avatar
BJ67
Thank you for responding and I am aware of those shift lights. A true shift light is adjustable so you can see when to initiate a shift just before redline without watching a moving shift light or tach needle. That makes the dash shift light useless for 1/4 use.
At what point would you shift using the shift light system provided with out hitting the fuel shut off? all you have is a series of lights left and right coming closer to each other. If you shift when they touch, its to late.
Old Feb 18, 2016 | 12:17 AM
Currently, I run 1/2 mile and one mile events. I reach max. HP at ~6,000. I shift at 6,500. I do not do "No Lift Shift". Your request indicates you are in a precision space. I am still a backyard racer. My next mod is getting the right wheels for those events.
Old Feb 18, 2016 | 06:57 AM
Elite275's Avatar
Elite275
Any reason for not "no lift shifting"?
To Help to wire a shift light
