Slight engine miss at idle?
Old Feb 18, 2016 | 01:21 PM
cg02175's Avatar
cg02175
Default Slight engine miss at idle?
My 2014 C7 manual seems to have a slight miss when idling? Has anyone else experience this? It seems I can feel and hear the engine miss at idle when I am sitting in the car.
It also seem to have a slight miss/hesitation every so often when I am cursing at highway speeds in eco mode.
I am plan on taking it to the dealership, but i wanted to get others thoughts/experiences.
Old Feb 18, 2016 | 03:37 PM
TennisFreak's Avatar
TennisFreak
Valves probably coked up pretty good and need to be cleaned.
Old Feb 18, 2016 | 04:25 PM
raylo's Avatar
raylo
Possible but unlikely. For many of us this is happening brand new.
Old Feb 18, 2016 | 05:34 PM
cg02175's Avatar
cg02175
I doubt it. It has had this miss in it since it brand new, and the car only has 2600 miles on it now.
Old Feb 18, 2016 | 06:36 PM
thrilled's Avatar
thrilled
Many C7's have A little of A rough idle.If it matters take it to A dealer they'll computer it for you
Old Feb 18, 2016 | 07:00 PM
MikeLsx's Avatar
MikeLsx
i know mine has had a rough idle from day one, and hesitation.
Not really a fan of the lack of fine tuning that went into the c7 OEM calibration
Old Feb 19, 2016 | 07:27 AM
RussM05's Avatar
RussM05
Same here.
The M7 factory idle speed is set at 600 rpm. When I tuned it, I raised it up just a little....to 650 rpm. That seemed to help smooth it out. The A6 idle speed is set higher.
Old Feb 19, 2016 | 11:24 AM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
This is the same subject the poster put in C7 General Discussion and I'll give the same answer.
Obviously the younger guys don't know about hot cams and rough running lope at idle. The lope is the result of valve timing overlap and goes away with increased rpm's. That's one of the ways you get increased performance out of an engine
Old Feb 19, 2016 | 11:34 AM
thrilled's Avatar
thrilled
Everyone needs to remember this isn't an Impala,lol
Old Feb 19, 2016 | 12:04 PM
Mr. Jones's Avatar
Mr. Jones
rock and roll it's all good.
Are you driving in eco when you feel the hesitation on the highway?
If yes it's V4 to V8 change-normal.
To Slight engine miss at idle?
