E-Force / Meth
Old Feb 18, 2016 | 03:10 PM
Johnq1211's Avatar
Johnq1211
6th Gear
Default E-Force / Meth
Just curious, does anyone have the e-force setup with meth? I have just the E-force and headers with tune on an auto 15' C7, 6psi put down 530rwhp / 550rwtq. Doing Meth and pulley to run 9psi. Anyone have similar setup? What kind of numbers should i be expecting?
Old Feb 18, 2016 | 05:19 PM
Redline Motorsports's Avatar
Redline Motorsports
We have done several E Force installs with meth....not much different then any of the other brands. Gaining another 70-100 is obtainable depending on "tune up".
The DI motors like the additional cooling on the intake valve as well.
HT
Old Feb 18, 2016 | 05:22 PM
T/A KID's Avatar
T/A KID
HT
Howard you guys try to do direct port meth system on any of these??
I have a pd blower on my stingray and I've thought about doing a direct port meth system
Old Feb 18, 2016 | 09:11 PM
Bucknut2006's Avatar
Bucknut2006
Also curious how meth is plumbed on a PD setup. I know a lot of CTS-V guys use it, but never looked at setup in person. I need to get out more
Old Feb 18, 2016 | 09:47 PM
Redline Motorsports
For a stock engine that has its mechanical limits I don't see the great value in investing into a direct port style system. I mean it wouldn't hurt you but again at pressure levels the stock motor typically lives at you'll get all you need prior to the blower. We've done a few NOS e Force builds and put the nozzle just after the throttle blade tapped into the snout. Take advantage of the T MAP sensor and calibrate the IAT spark retard table as needed for back up...
To E-Force / Meth
