Corsa x-pipe header flanges not centering on the x-pipe
Old Feb 20, 2016 | 01:01 PM
dvandentop's Avatar
dvandentop
Default Corsa x-pipe header flanges not centering on the x-pipe
in process of installing my corsa pipe now but the xpipe header connections are not mating up the passenger side donut and xpipe connection are not lining up. has anyone had to tweak the xpipe or cut the center brace on the x pipe to get them to line up??
have been messing with it for half hour trying different combos but the header donuts just wont line up.
thanks
Old Feb 20, 2016 | 01:34 PM
BJ67's Avatar
BJ67
thanks
Post some pics.
Old Feb 20, 2016 | 08:34 PM
Jack Be Quick Racing's Avatar
From: Detroit area and Nashville area What day is it? Between MI & TN
no, it was a straight up bolt in - no tweaking or cutting.
Old Feb 21, 2016 | 06:50 AM
BarneyZ's Avatar
BarneyZ
Sure you got it right side up?
Old Feb 21, 2016 | 11:56 AM
dvandentop's Avatar
dvandentop
ended up getting it straight and all connections leak proof. just took some cininching down of the bolts at the header connection to get further tightented then got it all going good.
Old Feb 21, 2016 | 12:18 PM
C7 x 2's Avatar
C7 x 2
I had the same thing with the Borla x-pipe but I don't think it is the fault of the pipe. I think the donut gasket hangs up in the flange. I bolted up one side and .used a clamp that can be flipped around so that it spreads instead of squeezes. Popped right in place
To Corsa x-pipe header flanges not centering on the x-pipe
