Dash reads 2.9 volts when I shut the engine off??
Old Feb 25, 2016 | 01:47 PM
xcpilot's Avatar
xcpilot
Default Dash reads 2.9 volts when I shut the engine off??
I had my 2016 vert in recently and had a Magnussen supercharger installed and a tune. The car runs fine but whenever I shut the engine off the voltage reading drops to 2.9 volts and I get a low battery reading. When I start the engine it immediately jumps to 14 volts and everything seems OK. My tuner so far has not been able to figure it out. Has anyone seen anything like this?
Old Feb 25, 2016 | 02:53 PM
Kracka's Avatar
Kracka
Sounds normal. My 2014 does this now, and did it when brand new and stock too.
Old Feb 26, 2016 | 01:57 AM
C7Kevin's Avatar
C7Kevin
My 2015 Z51 is dead stock and it does the same thing.
Old Feb 26, 2016 | 02:57 AM
xcpilot's Avatar
xcpilot
Thanks for the replies, there is one more thing in play on my car. I now get a low battery message on the dash every time I shut the car off and restart it. This began when the supercharger was installed. I thought the 2.9 volt reading was the reason, but evidently my car probably did this from day one and I did not notice it (I had no reason to look for it when there were no fault messages on the dash). I can post pictures of the message if anyone wants.
Old Feb 26, 2016 | 03:34 AM
xcpilot's Avatar
xcpilot
Here is the message I get every time I do a start up.
Old Feb 26, 2016 | 08:43 AM
Kracka's Avatar
Kracka
I've never gotten that warning and I am tuned now. Something isn't normal if this warning just started popping up after you got a tune.
Old Nov 11, 2016 | 06:02 PM
djmz51's Avatar
djmz51
Default same problem here
Any updates as I am having the same problem. Low battery everytime I start the car from day 1.
Old Nov 11, 2016 | 06:16 PM
djmz51's Avatar
djmz51
did you dealer fix the issue. what is the cause/fix.
Old Nov 11, 2016 | 09:43 PM
Higgs Boson's Avatar
Higgs Boson
never got that in my 14 with up to 5000 miles and haven't had it in my 16 Z with 3500 miles....
Old Nov 12, 2016 | 02:55 AM
xcpilot's Avatar
xcpilot
When I returned to Canada I took the car back to my original dealer and they found a problem with one of the battery cables. I suspect it may have been damaged during the supercharger install. Anyway they replaced one of the cables and I have not had the low battery message since.
Old Nov 16, 2016 | 01:34 AM
Bill Dearborn's Avatar
Bill Dearborn
The battery ground has a sense wire on it as well as the ground cable. If the sense wire is broken (easy to do when removing the cables/battery you can get a low battery warning).
Bill
To Dash reads 2.9 volts when I shut the engine off??
