Torque Management and Drag Radials
Old Apr 11, 2016 | 09:12 PM
cg02175's Avatar
cg02175
Default Torque Management and Drag Radials
I went to the drag strip with drag radials, and during hard launches the car cuts power just after leaving the starting line. I had my car (2014 M7-Z51-non msrc) in track mode with the TC and Stabilitrak turned off.
Anyone else experienced this? Does this relate to torque mgmt? Would a tune fix this?
Old Apr 14, 2016 | 01:01 PM
robert miller's Avatar
robert miller
It could be the tq mgmt. but this shouldn't be going on with the car. I have a auto with no problems with it, But also could be pulling big timing from the car. What gas are you running in here. If this s the case not good you don't want to end up with a blown up motor...Robert
Old Apr 15, 2016 | 01:55 AM
cg02175's Avatar
cg02175
You won't experience near the issues with torque mgmt. because you have the automatic. Due to being able to leave at high rpms with the manual tranny, the torque mgmt. is much more significant in the manual C7s
I am running 93 octane.
Old Apr 15, 2016 | 04:13 PM
MIGHTYM0USE's Avatar
MIGHTYM0USE
for me this was the engine oil starve protect check box.
Old Apr 15, 2016 | 05:52 PM
cg02175's Avatar
cg02175
Old Apr 17, 2016 | 10:35 AM
MIGHTYM0USE
i do not understand your reply
Old Apr 20, 2016 | 01:00 PM
cg02175's Avatar
cg02175
What are you referring to exactly?
Old Apr 20, 2016 | 04:33 PM
Higgs Boson's Avatar
Higgs Boson
in the tune
Old Apr 21, 2016 | 10:59 AM
cg02175's Avatar
cg02175
What would be the science/thought process behind the car cutting power during hard launches as it relates to the oil starve feature/check box? I have a dry sump oil system (Z51-option), so the oil should be pressurized. Do you think the oil may be sloshing around or pushing to the back of the engine during hard launches, thus causing the engine oil starve feature to cut power to the car as a safety mechanism? Any advice is appreciated.
Old Apr 21, 2016 | 11:15 AM
Higgs Boson
There is nothing to measure it, it is predicted based on driving conditions. It can "activate" even if there is no physical issue....there are quite a few things in the tune that are predictive like this.
Old Apr 21, 2016 | 02:08 PM
cg02175's Avatar
cg02175
What exactly was your corvette doing prior to you addressing the issue via the engine oil starve protect check box? Does your car have a dry sump oil system (i.e. Z51) or wet sump? Thanks
Old Apr 21, 2016 | 02:55 PM
MIGHTYM0USE
2014 z51 - during hard launches the car cuts power just after leaving the starting line
Old Apr 21, 2016 | 03:25 PM
cg02175's Avatar
cg02175
Good information, and thanks. That sounds exactly like what my C7 is doing. I didn't really noticed the issue until I put drag radials on the car, which allowed me to leave the starting line more aggressively.
How did you resolve the issue/? Did you check or uncheck the box during tuning, and what exactly does checking/unchecking the box change within the car/tune?
Old Apr 21, 2016 | 03:32 PM
Higgs Boson
he said he resolved it by disabling the oil starve torque management. i disable it in all of my tunes as standard procedure and I would think other tuners do also.
disabling it simply prevents the ECM from closing the throttle or pulling the spark lead when the criteria is met for the oil starve function to activate.
don't try to read too much into it.
Old Apr 21, 2016 | 03:39 PM
cg02175's Avatar
cg02175
Got it, thanks!
Old Apr 22, 2016 | 09:29 AM
MIGHTYM0USE
let us know if it dose the trick for you
Old Apr 22, 2016 | 11:39 AM
cg02175's Avatar
cg02175
Will do, and nice pass!
Old Sep 14, 2018 | 01:27 PM
badass1g's Avatar
badass1g
Bump, did the adjustment cure the issue? Any updates?
Old Sep 14, 2018 | 11:23 PM
phantom1's Avatar
phantom1
Check to see if your tires are rubbing after you launch. I lowered my car and had the same experience, and thought it was power loss. I found my tires where rubbing only after hard launches, because the car would squat down on the tires, and the tires might possibly grew during the launch. I raised the car back to original height and that solve the issue I had.
To Torque Management and Drag Radials
