My 2014 z51 has a rough idle, not quite a miss, just not perfectly smooth. Is this normal or do I need to bring it back to the dealer?
Mine (base m7) does the same. I drove another c7 automatic and it idles similar way. So i concluded that its normal. I also dynoed my car just to make sure. Made 413whp Stock.
Unfortunately this is normal. I have had 3 LS1s and 1 LT1 (new one). They all did the same thing. I am not sure whether this GM tuning, or GM engine control management system or a combination of the two.
One of the professional forum tuners may comment.
I would hope so since the engine is 3x or more. However this is not the cause for the "stumble" which has been in my cars intermittent in nature. Actually the stock cam profiles are pretty mild for the displacement of these engines (small duration, wide lobe separation).
I also don't notice this in Ford engines (I own one of those too) In the V8s they are getting almost the same horsepower from a smaller displacement engine. I guess they have Camry camshafts.
Still looking forward to a "professional" tuner to respond or someone that swapped out the injection for a carburetor without a cam modification (hard to find) to prove the point.
I have a 2015 Mustang GT (Coyote motor) and agree it is VERY smooth, but also a DOHC motor and realistically a completely different animal. The big ol pushrod motors do just rumble a bit more (even with the stock cam) and is pretty much normal.
I really dig the coyote motor, but there's nothing like a little rumble!
I have a 2016 GT and while it idles smooth, it varies RPM more like it's working a lot harder to adjust which is quite annoying.
My C5 Z06 and my C7 when it was stock both had/have a little lump to them but hey what do I know? Maybe someone should post a video so we know what they are talking about in the first place.
I believe what the OP is talking about is an intermittent stumble at idle. The engine will run smooth for x amount of time, which changes from time to time, and then stumbles a bit.
My opinion is that it is just due to the way GM software commands fueling for the engine and is not out of the ordinary. This may be able to be tuned out or it may not. If it can't be tuned out due to the way the engine management system operates, only an alternate method(carburetor or aftermarket fueling system would achieve anything different.
Is it a stumble one can actually feel, as in butter smooth then it acts like it misses and then gets smooth again? Or are we talking about the tachometer moving? I would not be surprised if some cars have "smoothed" tachs that don't show minor discrepancies. My Mustang tach also will hold an RPM, drop 100, hold, raise 100, hold, raise another 100, hold, etc. It isn't smooth if that's what we are talking about.
If it isn't just OCD tach watching, then there are a lot of things that happen like AC compressor going on/off/engage/disengage, evap system actuation, etc not to mention rising IATs (and maybe also ECT) while sitting at idle and of course there will be corrections for that. The torque based ECMs used today will move the throttle blade a degree or two at idle, move spark lead around, etc to maintain a desired idle torque level. Gone are the days of a set spark and a set TB blade. It's all dynamic now in pretty much all cars that I know of.
Personally, I like the slightly lumpy idle. It gives the engine some character, something that's missing from many modern engines. Most are too smooth and quiet, for a sports car at least.
Me too. I ran a Katech Torquer 110 cam in my C6Z, the whole car would shake at the stop light. People stared at me like something was wrong with the car
Well that is EXACTLY what I am talking about, however not 100% sure about the OP. He will have to respond if that is what is causing his perception of a miss at idle.
I do agree with the above and don't expect a perfect level of idle as you are correct with loads on the engine at idle increasing decreasing (alternator and A/C). The annoying part is the stutter or miss that you mentioned in the first paragraph.
