No sound when turn signals are activated
Not that it's a big deal, but sometimes there is no sound when I activate my turn signals. Then the next time I drive it, they make the normal sound when activated. Any one else have this issue?
I have this happen intermittently. I throw my signal on and it'll make a sound for a second or two then it'll be quiet for a sec and make a noise again.
Search for the TSB with the title "Elderly Corvette Drivers Cannot Hear Sounds Higher than 3000Hz".
Just kidding, but you lose your higher frequency hearing as you get older. I think that's why you see old drivers with their signals stuck on, or part of it...
LOL. Off topic, but there are some cool hearing tests on the net with different frequencies. My wife and I use them to see whoes getting older quicker.
My 2015 Z51 has the problem, too. As well as completely cutting out, it is sometimes just attenuated. The nav system voice does the same thing. Although I had wished it was just my imagination, unfortunately, it was not. )
I searched the web for a TBS associated with this and found none. However, the GM Tech Link does talk about a similar problem with the Colorado. It discusses the symptoms as being poor quality audio, intermittent cut-in/cut-out, as well as not working and then, for no reason, starting to work again. In this report, it advises that pinched wires through cable runs, spread terminals in the speaker (causing intermittent contact) or an incorrect connector as possible causes.
In discussing the issue with my dealer service advisor, he says that they have seen the problem with a number of vehicles, to include the Cadillac ATS/CTS. So . . . into the shop Monday to see where we go with this. More later as I learn . . . .
Got my problem fixed at my dealership. I chatted with the tech when I took the car in, explaining the problem and he searched for a bulletin on this. The service bulletin is 18-NA-141. The tech wrote on the order, "Installed 13575580: SL-N-Wire (0895-BOPCK) 13575 Qty: 2." When I picked the car up, I also talked with him about the repair. The wiring replaced is a pigtail that connects to the main door wiring harness and runs up to the speaker in the left door.
Seems to have fixed the problem as it has not come back in the last few days. I'll add anything more in the future, if needed.
I ran into the same problem when I upgraded my stereo. The Middle speaker on the Driver's door handles the phone speaker and chimes. I reconnected the speaker and those things started working again.
This happens to me all the time. I give a small hit to the speaker grill and it starts working again. Sure it's just a lose connector from when my glass got broken and replaced.
