CAGS on 2016 M7 Z51
CAGS on 2016 M7 Z51
Can anyone help me install the 1-4 shift eliminator on my 2016 Z51.
I looked under the car in what I thought was the location I needed based on this video:
My underside doesn't look anything like what I see in the video or I'm looking in the wrong place. If I'm looking in the same place as the video I'm looking at what I think is the starter motor and I don't see anything that looks like the plug I should be looking for.
Any help (especially photos) would be greatly appreciated.
-Mickey
-Mickey
I haven't installed one in a C7 but from the video and knowing the transmission is in the rear of the car I can tell you that exhaust pipe in the video is before the drivers side tire. I put cat back on mine and that is what the exhaust looks like from underneath the car.
MickP (05-17-2016)
Just installed it. Took longer to strap it down with the plastic strap than it did to hook it up. Everyone was right, 5 minutes top once I had the right end!
Thanks,
-Mickey
Love your comment...good job!
I agree the video isn't clear where the cags should be installed. I knew the trans was in the back, but thought the electronics might be up front, so I first drove up on ramps and crawled under. Then I couldn't find anything, so I jacked up the rear.
I wasn't clear on which way one piece plugged into the wiring, as mine didn't fit either way. I found I'd bent one of the pins just enough it wouldn't plug in...easy after finding that.
Photo was taken 2 days after I took delivery...wife was just shaking her head.
xxaarraa (05-18-2016)
I'm old school and just assumed the trans was behind the engine and the was in a thread I read earlier about installing the cats eliminator, "The correct spot is on the side of the trans on the passenger side." So I had two things going against me in my search.
All's well though, installed and working perfectly.
Like the Blue and chrome combo. Looks like you have a young "assistant" to help.
-Mickey
- Is that the 3 ton harbor freight 'racing' jack? How do you like it?
- Are those rhino ramps in the front? I have a set of rhino ramps, but was wondering if the nose was high enough to climb the ramps. I have an RPI splitter, but not lowered.
- Where are you jacking the rear end from? Diff pumpkin?
