Sharkbar question
Subscribe
May 29, 2016 | 10:17 AM
I have Z06 without competition seats. Is it safe to use seatbelt harness with sharkbar, or would I need to swap out seats? I'm doing HPDE or track days only for fun. Or is it better to just use the factory seatbelt since I'm not doing any racing?
Thanks for the advice.
Reply 0
May 29, 2016 | 02:54 PM
You can use any seat, no problem! That said, both competition and GT seats are not designed for 5/6 pt. harnesses, and they're best used with 4 point. Such harnesses would cause you to submarine in the event of an accident, though, so you should get a special harness that would prevent such a case, like Schroth Profi II ASM.
Have fun!
Reply 0
May 29, 2016 | 09:21 PM
Thank you. That's what I was looking for.
Reply 0
May 29, 2016 | 09:34 PM
I use a six point harness with the GT seats. Vetteworks is where my harness bar and lap mount bar came from. This gives you the six points for the harness attachment. I have the Racequip six point HANS camlock harness. I am assuming this is safer than factory belts, but I can't tell you for sure since I am not an expert.
Reply 0
Jun 9, 2016 | 12:34 AM
I have a shark bar and six point harness installed with the standard seats. I just pulled up the seat covering material at the bottom of the rear of the seat back and ran the anti-sub harness section (anchored to the floor behind the seat) between the seat back and lower seat section. That set-up keeps me anchored very solidly.
JV
Reply 0
Jun 9, 2016 | 11:21 PM
Quote: I have a shark bar and six point harness installed with the standard seats. I just pulled up the seat covering material at the bottom of the rear of the seat back and ran the anti-sub harness section (anchored to the floor behind the seat) between the seat back and lower seat section. That set-up keeps me anchored very solidly.
JV
Check your sub belts were they go through between the seat bottom and the seat back to see if they are damaged. There are sharp edges between the two parts and sometimes the belt can be damaged. Any damage means it is due for immediate replacement. One of the Vetteworks pictures showing how the belts are run also shows a damaged belt that has to be replaced.
The other thing you need to do is to sit in the seat with all your equipment and the belts fastened just like they are when you are on track. Then have another person check the shoulder belts to make sure they aren't not touching any part of the seat where they pass through the seat. If they are then they shouldn't be used until you can determine a seat position setting that lets you sit properly with the belts not touching any part of the pass through. I found on my GT seats I had to tilt the seat back further forward.
Bill
Reply 0
Jun 10, 2016 | 07:34 AM
I'd use the Brey-Krause bar because 1- it is easier to install, and 2- there are two different height bars for the shoulder belts depending on which seats you have.
Reply 0
Jun 10, 2016 | 11:42 AM
Quote: Check your sub belts were they go through between the seat bottom and the seat back to see if they are damaged. There are sharp edges between the two parts and sometimes the belt can be damaged. Any damage means it is due for immediate replacement. One of the Vetteworks pictures showing how the belts are run also shows a damaged belt that has to be replaced.
Bill
Thanks Bill, I just checked and there doesn't appear to be any worn areas. I'll keep checking on a regular basis.
JV
Reply 0
Explore
Jun 10, 2016 | 03:10 PM
Food for thought:
I contemplated doing the same thing, but ultimately concluded that the opening in the back of the GT seats was too low for the height of my shoulders.
My experience with this is limited, but my understanding is that you risk spinal compression injury if the angle of the belts from the peak of your shoulders is greater than 20 degrees from horizontal. Fore me, feeding the harness through the GT seat opening would be too steep of an angle for safety.
Reply 0
Jun 12, 2016 | 06:10 PM
It would be great to see people's setups with the competition seats and the various harness bars. I understand it's going to be driver dependent, but knowing if one bar is more accommodating than another could swing my decision towards one versus another.
Reply 0
Jun 15, 2016 | 11:22 AM
Quote: It would be great to see people's setups with the competition seats and the various harness bars. I understand it's going to be driver dependent, but knowing if one bar is more accommodating than another could swing my decision towards one versus another.
A bit off topic from the OP's request but along with the post below, here are a few photos of the BK bar with comp seats.
Looking through the seats at the lower BK hoop
Quote: I'd use the Brey-Krause bar because 1- it is easier to install, and 2- there are two different height bars for the shoulder belts depending on which seats you have.
Even with the Comp seats, you use the lower bar. The upper would be used if you use aftermarket seats with taller openings.
To the OPs original question. I used the Schroth 6 point belts with BK mounts, sitting on the sub belts and felt good during my last track day, or as good as belts against the family jewels can feel. I recognize it is not as good as having a dedicated harness hole in the seat but it is a compromise that GM provided and I am stuck working with.
Reply 1
Jun 15, 2016 | 04:41 PM
They are too low compared to a race seat. However, what you need is a direct line from your shoulder to the bar with the belt not touching anything but you and the bar. If the angle is 22 degrees it is fine. If it is 30 then it isn't. The rule isn't a steadfast 20 degrees. Both the BK and Shark Bar get the bar low enough so you can get the angle. With my comp seats I found I had to tilt the seat back forward just a bit to keep the belts from touching the seat passthroughs. There are some people here using the GT seats with harness bars with no issues.
Using the 3 point stock belts in cinch mode will hold you in place just about as well as a 4 or 6 point system since both the comp and gt seats have nice side bolsters to keep the upper body from moving around. When in cinch mode the shoulder belt and lap belt are locked in place and if you do it right they will hold you tightly between the bolsters. If I didn't wear a HANS I probably wouldn't have bothered with a 4 point Schroth ASM belt system and just stayed with the stock setup.
Bill
Reply 1
Subscribe
