Rear bumper started falling off, panel gap increase
Old May 31, 2016 | 04:13 AM
BrandonAGr's Avatar
BrandonAGr
Default Rear bumper started falling off, panel gap increase
Walking by my 2014 one day I noticed that the panel gap at the top of the rear bumper cover driver side was all of a sudden more, there were no marks to indicate it had been hit or run into.
After getting the bumper off
Turns out some plastic that was heat welded together at the factory let go, the three red clips on each side are the only thing aligning and holding the rear bumper along that seam, the red clips snap into plastic that is heat welded to the bumper itself.
I used some super glue + activator to reattach the parts that had come off, but I couldn't get it aligned very well, the only adjustment being losening and sliding around the 4 torx screws holding the plastic piece with the 3 red clips, it's better than it was, but the passenger side actually looks correct with the top edge of the bumper lining up with the body
Has anyone been able to do something to improve this panel gap?
Old May 31, 2016 | 06:04 AM
jyounger74's Avatar
jyounger74
Take the car to the dealer if the car is under warranty it is covered. That gap is way to wide.
Old May 31, 2016 | 10:15 AM
TNSQUIRE's Avatar
TNSQUIRE
I had panel gap issues along that same seam on my 2014. After several attempts by my dealer to adjust it, they finally replaced the bracket you referred to. Still not perfect but much improved.
Old Jun 1, 2016 | 07:57 PM
kb's toy's Avatar
kb's toy
I had the same problem but at the bottom of the passenger side. Dealer made it worse.
Old Jun 7, 2016 | 01:44 PM
havocatl's Avatar
havocatl
I'm having the same issue myself on my 2015 Z51. Just noticed it today. Taking it to the dealer on Monday, hopefully they will fix it along with the creaking top.
Old Aug 3, 2017 | 08:58 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
My 2014 just developed this issue and it appears the rear fascia pulled away from the inner liner as did the OPs. As I have 42K+ on mine, it is technically out of warranty (although I do have the Platinum GMACC plan but the body is an exclusion so....)
I am planning on escalating this to GM as it is clearly a design and/or material defect since so many are affected by it. (I did go up against GM about my C5Z06 in 2008 and after months of effort, they finally agree to reimburse me for the amount I spent because of THEIR screwup.)
Anyway, it would be good to know how many C7 owners have had to deal with this issue and if you spent money to fix it or even if you haven't had it fixed.
(if you're interested in the gory details of my last go 'round with GM over these sort of things)
https://www.corvetteforum.com/forums...?highlight=BCM
(bookmarking this page for (hopefully) lots of folks commenting on their woes)
Old Aug 4, 2017 | 09:40 AM
danh63's Avatar
danh63
I just noticed over the weekend that my passenger lower side gap is rubbing. I do not trust my Dealer at all. Not to hijack the thread but is this an easy adjustment for me to try?
Old Aug 4, 2017 | 01:55 PM
HAD2HAV2's Avatar
HAD2HAV2
BrandonAGr, sorry about your problems. This wants me to think twice about installing a rear high wing spoiler (that requires removing the rear bumper) on my 2015 this fall when I retire. How long did it take to remove your bumper? Did you need 2 people for the job?
KenHorse, nice to see you around again.
Old Dec 9, 2017 | 07:15 PM
RapidC84B's Avatar
RapidC84B
Thanks for this post... sometimes things they do to make it "better" are worse. The C5 was tedious to take the bumper off, but you could easily line up the fascia to the quarters as you tightened the nuts on the metal bracket. This is basically it fits or it doesn't.
Old Oct 16, 2018 | 04:39 AM
CorvetteV's Avatar
CorvetteV
This thread was very helpful to replace my reflectors to LED reflectors. Thank you!
Old Mar 15, 2023 | 06:49 PM
JorgeAM's Avatar
JorgeAM
Just happened to me on my 15' Z51!!
Old Mar 15, 2023 | 10:27 PM
dcova's Avatar
dcova
I had the exact same problem with my 2017 Stingray. The plastic heat welding along the top driver side of the bumper never took properly from day one. The fix was to replace the entire rear bumper after a fender bender.
To Rear bumper started falling off, panel gap increase
