A8 TCM Confused
My A8 has done something very curious twice now, and I am wondering if anyone else has seen the same thing...
It is a 2016 Z51, build date of October 2015. Transmission has been flawless operationally, and I am not easy on it at all. It has been perfect in every way.
But two different times now, I have had a condition wherein I start the car, the check engine light is on, and the transmission is stuck in 4th gear, no matter if it is in "D" or "M" mode, almost like it is in a "limp mode". Also, when putting it into gear, it hesitates, then clunks into 4th gear. Reverse still works normally as well.
The only way to fix it that I have found, is to disconnect the battery for a minute or so, and then reconnect. Everything is normal after that.
After some thought and correlation, it occurred to me that the only thing I have done out of the ordinary each time it has happened, is that I had turned the ignition on and off a few times, without starting the car (like to roll windows up or down). I plan on trying to re-create the condition, now that I figured that out to be sure, but was wondering if anyone else has experienced this particular issue (not any other issue, just this one)?
UPDATE:
So I just found some other info about this, and it seems it could be related to the use of the Range AFM disabler (which I have). It may be because I leave it plugged in all the time, and it doesn't like on/off ignition changes.
UPDATE 2:
It is the Range module. After extensive testing, I only have the issue under two conditions:
1) If I turn the ignition on and off a couple of times and then try to start the vehicle. If I know I am going to be turning on and off the ignition only, then I just pull it out beforehand. When I am ready to drive, I put it back in and it isn't an issue. No problems with it, as long as I remove it when turning the ignition on and off repeatedly (like to roll up windows, or listen to radio, etc).
2) Jump in car and start immediately (like a few seconds after opening door). It seems like the car needs a short amount of time to boot up, before starting the car, or it can get confused. This has only happened once so far, and it was a very short time between opening door and starting.
I think the ground issue is unlikely, as it only happens when the car is off, and then started, and others with this issue that had a ground fault were having it happen while they drive. It is easy to fix when it happens, so for now I will see if I can reproduce this weekend, and verify it is the Range AFM device.
Whatever the case, it would seem the TCM does not like power on/off cycles in a rapid manner, so I will need to be cognizant of that as well in the future.
Thank being said, definitely try removing the Ranger before you bring it in and see if it keeps doing it.
GM replaced my complete tranny back in June 2015 with 100 miles on the car as the TCM was bad and it would cause all kinds of shifting problems, car would back fire, and loose connectivity to the TCM altogether. Back at that time, GM would not let the techs replace the TCM standalone.
Don't just buy a new TCM and expect to replace it yourself, unless you can flash it. I was told they come blank.
https://www.corvetteforum.com/forums...-4th-gear.html
