Will these wheels fit?
Old Jun 6, 2016 | 01:31 PM
"BoneStock"'s Avatar
"BoneStock"
Default Will these wheels fit?
So im about to pull the trigger on some new wheels and tires. I just want to double check and make sure they will fit correctly. They are Cray Spiders 19x9 +50 up front and 20x11 +76 in back. The car is a 14 z51. I had cray brickyards on my last 14 z51 and they fit pretty decent and are close in spec but not exact. I just want to be 100% sure before i order. The tire specs will be 315/30r20 r888s in back and 245/35r19 hankook ventus v12 up front.
Old Jun 6, 2016 | 02:14 PM
Elite275's Avatar
Elite275
I would think they may stick out some. I think my Forgelines have an 82 or 83 offset in back and sit flush and I'm also running a 20x11 with the R888 in 315/30/20. It may not be too bad though and I'm sure someone here probably has the same exact rim.
I ran the TSW Nurburgrings before this in a 19x10.5 and the offset wasn't enough and it stuck out a bit and rubbed with 285's. It didn't look terrible but the rubbing bothered met. Mine is a base with Z51 sways so the suspension is still probably a bit softer than yours.
Old Jun 8, 2016 | 05:27 PM
"BoneStock"
My last crays stuck out very slightly and these have +3mm so they may be a little better. I went ahead and ordered them so we will see in about a week!
To Will these wheels fit?
