Has anyone with an M7 tired launch control with drag radials? I have some and want to try it because on the stock tires, launch control was useless for me. Would spin way too much and get a 5.0+ 0-60 every time.
Figure with DR's it may actual hook. I'm having a bit of trouble testing though because of a recent disaster my small city is packed with people and extra police and my car can be heard for probably 15 blocks haha.
It should hook better just hope you don't break a axle if it really hooks up good.. But if you are not running a S/C in the car should be good...Robert
The key with a stick is to not shock the tires. Once you shock them and they start spinning you are done. You need to initially engage before full release even with a drag radial. The suspension on the corvette is not conducive to a big throttle clutch dump, you just don't have the travel/motion to absorb it.
This is a road race car from the ground up.
100% these cars not made for a dig race. To the OP here good luck in her man. Robert
