So I am looking into getting my Z06 a track alignment. Has anyone else gotten a track alignment for theirs? Is there a major difference from the factory alignment?
I was quoted $350, not sure if that is high for a track alignment on this car... Let me know what you guys think!
I'm not sure of the differences between the Z06 and my Z51, but a track alignment will definitely help, both in the handling and tire wear. The difference between track settings and factory depends on how far you want to go. For example, the Z51 stock front camber is -0.7 deg and for the track I use all I can get, at -2.5 deg. My local speed shop has state of the art equipment and he charges $175 for a full alignment. YMMV
JV
Did you have to remove all the washers to get to -2.5 degrees camber?
