Track Wheel tyre combo help
Old Jun 29, 2016 | 07:24 PM
Bryan Wharton's Avatar
Bryan Wharton
Default Track Wheel tyre combo help
Has anyone out there run, or is running the standard C7 18/19" wheel combo with 305/30R19 and 265/35R18 Toyo R888 tyres?
I am considering them for my 2014 Z51 as a track only wheel set up. Other cost effective suggestions please, based only on actual personal experience?
Old Jun 30, 2016 | 09:30 AM
Ttripp24's Avatar
Ttripp24
I run r888s in 265/295 18/19" on Lg Motorsports GT2 wheels on my 14 Z51. Not sure how price compares to OEM 18/19s.
Old Jun 30, 2016 | 09:39 AM
Along4theRide's Avatar
Along4theRide
CF Old Timer
St. Jude Donor '14-'15-'16
For my track setup I'm running Cray Spiders Front 18x9.5, Rear 19x11.0 with Hoosier A7 Front 275/35/18, Rear 315/30/19. This is the most performing combo I've been able to put together and the results have been exceptional.
BTW - my OEM Z51 wheels are 19/20s.
Old Jun 30, 2016 | 11:02 AM
jdarc1's Avatar
jdarc1
Im interested in the same info for any of you guys dragging and at 700 WHP
Old Jun 30, 2016 | 04:44 PM
Bryan Wharton
Thanks for the reply. I am concerned at how well a 305 R888 will fit the Corvette 10" wide rim.
What are the widths and offsets on your Lg wheels?
Old Jun 30, 2016 | 04:48 PM
Bryan Wharton
Thanks for the reply. Your setup, though great, is not practical for me in Australia. R888 are readily available here, Hoosier not so. I'm thinking that a set of 18 / 19" Corvette take offs are readily available at a good price. They should fit my Z51 brakes?
Cheers
Old Jun 30, 2016 | 10:13 PM
Along4theRide
CF Old Timer
Cheers
Those should fit. Good luck! Post photos.
Old Jun 30, 2016 | 10:24 PM
jacksnorm's Avatar
jacksnorm
I have a street/track wheel setup for sale that will work. Works on my car with over 700RWHP,
https://www.corvetteforum.com/forums...terlaggos.html
Old Jul 1, 2016 | 12:29 AM
Bryan Wharton
Sounds good. Are there any clearance issues at all? Inside or outside? Are you using spacers?
Could you show me a picture that details where the outside of the tyres sit relative to the outside face of the front and rear guards?
Old Jul 1, 2016 | 08:24 AM
jacksnorm's Avatar
jacksnorm
No clearance issues at all. The rear wheels do stick out slightly, but no rubbing whatsoever. Fronts are flush. No spacers required. I can take some pics today if you want shoot me your email address. These wheels are also about 8-10lbs lighter than the stock wheels.
Old Jul 6, 2016 | 01:28 AM
brent eb02's Avatar
brent eb02
What are planning to get next ?
Old Jul 6, 2016 | 08:49 AM
jacksnorm's Avatar
jacksnorm
I bought a set of RaceStars 18x10.5 and 17x4.5.
Old Jul 6, 2016 | 11:42 AM
Spulbus2013's Avatar
Spulbus2013
What are your rear offsets? What tires are those? thanks!
Old Jul 6, 2016 | 11:50 AM
jacksnorm's Avatar
jacksnorm
Rear offset is 76
MT Street SS DR 305/40/18 its a 28" tall tire, I am going to try it out so far no rubbing. I will mount my Hoosier DR2 315/30/18 if the car doesn't 60ft well.
Old Jul 6, 2016 | 12:10 PM
Spulbus2013
Thats awesome, How many miles so far? Have the tires been holding power on the street or are u a track only fella? My goals for the time being are getting a rear drag pack for some baby dig action of the street at a level of 500whp. Id love to use the new "Street R's" as ive seen them on an 18" wheel hold my friends 4.0 KB Shelby with 1200+whp from a 60 roll, very impressed with them!! < But the thing is they are 29" tall doubt they will fit and NOT rub.
Old Jul 6, 2016 | 01:05 PM
jacksnorm's Avatar
jacksnorm
From a 2nd or 3rd gear hit on the street they hook well @ 28lbs of air pressure. I haven't tried from a dig I'm sure it will spin on the street without peddling, and yes I am a Track guy I will post my results when I make it back to the track.
From 450WHP to low 600WHP my Nitto 555Rs hooked very well street and track.
Old Jul 6, 2016 | 01:56 PM
Spulbus2013
I have never used those tires but on my Pros and Pro Bracket's on my other car I usually use 16-18psi, maybe try lowering ur pressure test them out and see what happens.
To Track Wheel tyre combo help
