GEN V LT1/ LT4 cylinder head differences
Old Jul 20, 2016 | 02:03 PM
SDPC's Avatar
0SDPC
Former Vendor
Default GEN V LT1/ LT4 cylinder head differences
Here are some comparisons we wanted to display, showing the differences between Gen V LT1/LT4 cylinder heads.
Old Jul 20, 2016 | 02:41 PM
T/A KID's Avatar
T/A KID
Good pics... Easy to see why the difference in compression...
The lt4 head is a slightly different material as well
Old Apr 25, 2018 | 09:07 AM
Earl H's Avatar
Earl H
Sorry to resurrect an old thread...is there a difference in deck height/actual height between the 2 heads (e.g. will a given intake sit physically higher when installed on LT4 heads vs LT1 heads?)
Old Apr 25, 2018 | 08:16 PM
bigsapper's Avatar
bigsapper
Intake manifolds for LT1 & LT4 are not interchangeable.
Old Apr 25, 2018 | 09:04 PM
Earl H's Avatar
Earl H
With all due respect, Not the question...looking to understand height differences of the two heads.
Old Apr 25, 2018 | 09:31 PM
bigsapper's Avatar
bigsapper
With all due respect, what difference does it make? The intakes are fabricated specifically for the the head design. If you want to use an LT1 intake on an LT4 head it will require an adapter. Thus raising the intake. And vicy versy.
:thumb:
Old Apr 25, 2018 | 10:23 PM
JHEBERT's Avatar
JHEBERT
What Earl wants to know is....” are the decks .100 thicker on lt4 vs lt1 just like ls9 head vs ls3”. How’s that? I think they are rotocast t6 or?
John
Old Apr 25, 2018 | 10:25 PM
JHEBERT's Avatar
JHEBERT
:thumb:
With all due respect, one can use the lt1 intake on the lt4 by drilling/tapping the heads. Not so much the other way around...or maybe so. I have not that done.
Old Apr 26, 2018 | 04:55 AM
Earl H's Avatar
Earl H
John
Exactly!!
Researching swapping LT4 longblock into L86 truck with whipple 2.9. Adapter plats will add ~ 50mm, until yesterday disnt even consider potential head height difference...only so much clearance between blower and rear cowl.
Old Jun 8, 2018 | 05:18 PM
Pedaltheworld's Avatar
Pedaltheworld
2nd Gear
Seeing that they have different bolt patterns unless you plan on drilling & threading them...? They seem to have the same casting...
Old Jul 6, 2018 | 12:57 AM
Rdubfalco's Avatar
Rdubfalco
Does anyone know the casting number of the LT1/LT4 heads?
Old Apr 17, 2019 | 10:59 PM
qnitro's Avatar
qnitro
Can you drop LT4 heads on a LT1 or L86 to run a LT4 supercharger without adapters?
Old Apr 19, 2019 | 11:01 AM
sammy burks's Avatar
sammy burks
Active Streak: 90 Days
Default LT4 on LT1
Yes I have done it just use the LT4 head gasket
Old Mar 2, 2020 | 11:42 AM
WarShrike's Avatar
WarShrike
:thumb:
The current standing mile record car is running LT4 heads without adapters. They did however tap the LT4 heads for the LT1 intake pattern. This was after they found the ported heads had been taken too far by the previous builder and had developed cracks.
Old Dec 8, 2020 | 09:35 PM
allenk4's Avatar
allenk4
7th Gear
Is there significant advantage to adding the M8 Corner Bolts to the LT1 Heads?
The LT1 block is already drilled and tapped for them.
Old Dec 9, 2020 | 11:09 PM
99vetteran's Avatar
99vetteran
The Lt1/4 are the same block. I don't think there is a big advantage to the Lt4 heads. I'm sure the additional bolt is just added because of boost, but thats a guess. I ran up to 20 lbs of boost on my Lt1 heads and never lifted the heads, some are running more boost then that.
Old Dec 10, 2020 | 06:16 AM
goec2468's Avatar
goec2468
One benefit of the LT4 heads are the titanium intake valves and when running a supercharger, the lower compression ratio can help as well. Furthermore the LT4 head is somewhat more HD, if that is required, I don`t know.
Old Dec 10, 2020 | 07:40 AM
99vetteran's Avatar
99vetteran
Originally Posted by goec2468
One benefit of the LT4 heads are the titalium intake valves and when running a supercharger, the lower compression ratio can help as well. Furthermore the LT4 head is somewhat more HD, if that is required, I don`t know.
That is a good point on the Titanium Valves, they are light weight and stronger the Stainless Steel, the Lt1 does run a 11.5 compression and I believe the Lt4 is 10.0 so the chamber in the head is different then the Lt1 and of course the Pistons are different also to allow the lower compression over the Lt1 which has more of a dome.
To GEN V LT1/ LT4 cylinder head differences
