Rev Matching on Automatic C7s
does anybody know how to disable this??? the dealer tells me that there is NOT rev-matching on a automatic
thank you guys in advance
Manny
Manny
--Dan
Have you tracked the car at all? I am curious how it does when braking, downshifting and turning into a corner.
Learn that it is normal and you will be much happier.
Elmer
I like to know if any of the members have gone through this exercise before.
Manny
Elmer
Elmer
And drop it down to low.
Since then have did it to all the automatics I've owned.Transmission,drive shaft,rear held up on all of them.
Elmer
The A8 and A6 before it aren't getting slammed on downshift as the torque converter takes the hit. With proper use of the paddles you make your downshift ahead of the corner and there is no disruption from a gear change mid-corner as can occur in automatic mode.
Drive with the paddles, choose gears as you would in a M trans and you won't have an unsettled car anymore than with improper use of a M car. The shifting of the A8 is much better than the A6 I've raced for ten years. But, the A6 slows down with a downshift unlike the A8 that speeds up -- I suspect due to the rev-matching attempt.
It's not just at slower speeds either. I tested it on the highway and downshifting (without braking) from 4th to 3rd results in an initial slowdown followed by the car accelerating. How can that be correct?
I am tempted to see if it can be corrected in the tune. You do a lot of tuning, I believe. Can HP Tuner address this "feature" as it is not this way in my A6 car?
--Dan
When I first got the car, I would learn that a scrubbing downshift would cause a bit of extra power when coming off the clutch, and a slight surge forward, as opposed to slowing down, like I desired. I found that if I was on the brakes, even lightly, when downshifting the surging would be gone - Because I was braking, the car knew I was downshifting in order to scrub speed.
Maybe give this a try, when doing downshifts to scrub speed, also use a bit of brake, and see if you still encounter the behavior.
For those with a manual, this works, but I also found staying on the clutch just a quarter of a second longer allowed a very quick clutch engagement without any lurching (when downshifting to scrub speed.)
I'll make the effort to adjust from how the A6 works, as expected, to the A8 behavior of needing some brake for the computer to know what to do. @&^#ing computers!
--Dan
It seems to me that in traffic one should be using one's brakes when slowing down, brake lights to alert the traffic behind you of your intentions.
Yes, I do want it gone. It serves no purpose when under hard braking and on the street it's just annoying and potentially dangerous having the car lurch forward when expecting it to slow down.
--Dan
The only time the transmission holds RPMS and tries to keep in the lower gears is when you get the car into puppy mode. Puppy mode is when the car senses that you want to drive in a spirited manner and the car tries to keep the RPMs up to allow you to stay in the power band while the "puppy" mode is activated. If you are talking about the "puppy" mode and it being bad, I flat give up.
BTW, I have the 2014 A6 and it is supposed to work this way. The older A6 trannies might not have had the "puppy" mode.
From your comments in THIS post, you sound like you found "Puppy" mode. Congratulations! Have fun with it!
Elmer
Elmer
Do you mean paddle mode? If so, yes, I discovered it over 11 years ago and use it all the time. I was the first person to reverse the operation of the right paddle on the A6 to upshift when pulled as it now does properly on the A8.
--Dan
Elmer
Oh by the way, it's in the owners manual.
