Skip Shift Eliminator - Question (and pic)
Old Jul 29, 2016 | 06:33 PM
Former USMC's Avatar
Former USMC
Default Skip Shift Eliminator - Question (and pic)
Greetings,
I recently installed the Skip Shift Eliminator (SSE) in my 2016 C7 (manual) and was wondering if you have experienced the following:
On occasions, I still get the "warning" notice to shift from 1st gear to 4th gear. I am able to shift into second gear, but was wondering if this warning is normal.
Does the SSE eliminate the warning notification and allow you to shift into second? Or, just allow you to shift into second.
The warning notice presents itself when traveling less than 20 MPH.
Glitch in the SSE? Normal? Defective?
Thanks for your response.
Semper Fi
PS - Just installed the new Oracle LED side lights - all I can say is - AWESOME. Shark Gray with tint. See pic below.
Old Jul 29, 2016 | 07:09 PM
Rat Racer's Avatar
Rat Racer
Originally Posted by Former USMC
Greetings,
Semper Fi
Perfectly normal. All the Skip Shift Eliminator does is disable the servo which blocks out 2nd gear. So the computer still tells you that Skip Shift is engaged.
Hunter
Old Jul 29, 2016 | 07:11 PM
Former USMC
Hunter
Hunter,
Thanks - I'll rest easy tonight. Appreciate the response.
To Skip Shift Eliminator - Question (and pic)
