C7 Z06 clicking noise in rear end
My 2015 Z06 is coming up on 4500 miles. Started to notice over the last few days a clicking noise coming from the rear end. At first I notice this noise when I was backing out of my driveway on a slight turn. The I started over the last weekend to hear a click every time I start moving from a stop. Tonight I took the car into a parking lot, put the exhaust in stealth mode and tried to figure it out. I held the door open while I made stop and starts It clicked every time twice. Then If I turn in a circle either way the clicking is constant. And its defiantly not the tires. Has anyone else experience this issue. Thanks for any help you can give
I have the Same thing on my z51. Tried pushing and pulling on the quarter and no noise. At first it happened every time I started moving either direction. Now a few months later, if I tap the gas moderately while moving at 15-20 mph it also sounds. My spring has a bit of splintering on the top but I doubt that's it. Wondering if there is ball bearings or something.
It has me baffled. It defiantly sounds mechanical, but were its exactly coming from I can't tell. I want to have someone move the car while I am outside trying to listen. I will keep you posted.
It may be the NPP exhaust valves. I had a similar problem that ultimately got really loud. Dealer solved it by replacing actuators for the valves in the outer exhaust pipes. He referred to it as an "actuator kit".
Clicking Noise from Rear End
You describe a "click" as the symptom so this may not apply but on earlier GM and Corvette posi rear ends, a chattering or groaning sound from the rear differential was indicative of a slip/stick condition of the clutch plates, and was especially noticeable on slow speed turns (like in a parking lot). I had that issue on a Camaro a few years ago. Draining and refilling the differential and in those days adding a few ounces of a GM Posi lubricant would solve the problem.
Have you checked the fluid level in the differential? That would be one place to start.
MACMILLEN65 (08-19-2016)
I had my friend drive the car in a parking lot tonight. I listened from the outside,and it actually sounds like it is coming from the brakes. I can hear it at all wheels depending on what I do with the car. Now Im even more confused
Click In Rear End
Noises like that are tough to diagnose, especially from the passenger seat. Service Manuals contain flowcharts to help, including a description of the noise, under which driving conditions it occurs, whether or not it is dependent on engine speed, vehicle speed, load conditions, and much more. Also included are physical inspections and then the use of special tools that attach to the vehicle. I would recommend that you check the underside of the car for any physical evidence that could produce the noise. Maybe it is something simple like a small branch wedged near a moving part such as a wheel or axle. Also helpful would be to write down as much as you can about this noise to help pinpoint it in discussions with technicians. This will also be of value if you need to enlist the help of a dealer.
I mentioned checking the fluid level because there is a GM Bulletin noting that some 2014 Corvette differentials were supplied with insufficient fluid that could produce noise (although I know you have a 2015):
http://forumfoundrycdn.com/nickj/aut...etin_13384.pdf
Good luck.
Good luck.
MACMILLEN65 (08-20-2016)
Here is what I did today that seemed to get rid of the noise on my driveway tests. Pulled wheel, cleaned faces of wheel and brake, checked all nuts I could reach for tightness. Axle nut was about 1/4 turn loose by breaker bar torque, no others . There was a rubber spacer that keeps a line from rubbing on sway bar rhat was a bit misplaced. Made sure do a good star pattern on wheel.
Hope it's gone. Likely just some debris between wheel and brakes.
The following 2 users liked this post by BrunoTheMellow:
1ccrider (06-23-2017),
No support from GM!
I've had the same issue with my 2015 z51. It's been fixed over 6-7 times. PDF attached from GM causing the issue. The noise goes away for 3-4 weeks then comes back, depending how much you drive. I'm honestly over it. I processed a Lemon Law, dropping off my car for a final repair attempt tomorrow. I've been at service over 20 times in the last year for a brand new Vette for not only this issue, multiple issues (drivers seat noise cause by the fans, double image HUD after replaced windshield, clicking noise while turning) Driver seat noise has over 7 repair attempts and no luck! HUD over 3 repair attempts.
No support from GM!
No support from GM!
I'm having the exact same issue with my 2015 Z06 (less than 5,000 miles). Very loud clicking noise coming from the right side of the car (not sure which wheel) when turning. At first it was just with sharper turns at slower speeds. Took it in a few weeks ago and the noise went away for a day or two. Then the noise came back and is present during turns at higher speeds than before. Any advice or new information from others who have experienced this? Thanks!
fixing the Clicking
Received 8,928 Likes
Bill
My 2015 Z51 now clicks almost every time when proceeding after being stopped. The car is travelling in a straight line so it's not the wheel clicking issue when turning.
Stop at a red light or stop sign and then start up: click
I'm open for ideas before I go to the dealer.
pull wheel, clean behind wheel and face of rotor where they mate. fixed mine.
CP (11-11-2016)
Known issue for 2014 - 2015 models which is unacceptable. Getting rid of my 15 and jumping into a 2017 Grand Sport! Hopefully no issues!
I know it has been awhile since this thread has been updated. My 2015 Z06/Z07 clicks one time after stopping then starting. This is with the wheels straight and is only the rears. It happens within the first few feet of movement. The GM fix of cleaning lasts only a very short time. I have had the dealer attempt to fix this 6 times. I now automatically report it each time the car goes to the dealer for anything. I asked for factory rep involvement yet the dealer gets no help from GM. I felt that they would get tired of spending the 1.1 hours that the bulletin calls for. I guess it is too little a cost for GM to pay any attention to the problem.
Has anyone had any response from GM warranty on the cause and fix other than the bulletin to remove wheels and clean?
smspitler (05-04-2020)
I've been having an issue that I think is related. Often from the rear of the car, but occasionally from the front, I get a 'clink' sound when changing directions. For example, I drive home from work and then back into the garage. Upon shifting into reverse and backing up, I get a 'clink' from the rear after backing up a few feet. At one point i was getting the same clink sound ever time I'd roll on/off the throttle at a slow speed. This went away after tightening the rear axle nuts. Planning to have the dealer look for a cause this weekend. I've tightened all the visible bolts in the rear suspension without improvement.
