What part of the tire tread do I use to measure tread depth? Looks different on the inside/middle/outside.
I am planning on running at Sonoma raceway in 2 weeks. I have plugs in both of my rear tires. I am on a mission to incinerate them and change them before I do another track day. But I want to know when I am done doing burnouts =p
How do I keep this from happening again? I guess the obvious answer is to get another set of rims/tires to bolt on for track days. If I am going to do that, is another set of stock wheels the best way to go?
Another set of rims/tires for track duty makes me wonder if it is better to go a different route. Do aftermarket rims / tires play nice with PTM? ABS? Should I just stick with the stock set-up?
Don't know how to answer your questions but I'll be at Sonoma on 8/25 Thursday. Look for my car. Come and say hi. I'm running in the advanced group. Here is a picture of my car.
Assuming you are driving on a road course and not a drag race, how many road course events have you done?
I was confused for a minute. I guess you do drag stuff.
Been doing HPDE for about 4 years. Started out in a Nissan 350Z.
Needed a little more HP. Got my car end of last year. I really like this car.
This will only be my 3rd time on a road course. I have been drag racing forever. Seems like a waste of engineering to just drag race my z51. BUT because I have plugs in the rear tires, I have been burning out excessively at the drag strip and trying to finish them off before I go back on a road course. Where do I measure the tread depth? On the big straight rings near the middle? On some of the smaller grooves?
I want to finish off these tires but not have a blow out. I have a tread depth gauge and am keeping an eye on it.
When should I stop doing excessive burnouts? What tread depth? Or just wait until I see the cords?
I'm on my second set of cup 2s. I replaced them when the tread went down to the wear bars on the inside groove of the tire if I remember correctly the outside was not down to the wear bars yet but I saw that the inside was down to the wear bar and i replaced them
You need to check each groove. The wear bars that go across the tire leave a tread depth of 2/32 when you first hit them. If any one of them is wearing even with the surrounding tread blocks the tire is considered to be worn out.
However, you can get by with 2/32 of tread especially on the rear as the rear tires won't wear as fast. If you spin them on a road course you are doing something wrong or there is something wrong with your car. If you are at 2/32 on the front tires (especially the outer and inner edges) you might want to think about replacing them.
Aftermarket wheels and race tires will work well on the Corvette as long as you choose the right sizes and offsets for your car.
Bill Dearborn's advice is spot on regarding wear. I ended up buying a set of OEM Speedline wheels with Cup2 tires from one of the sponsors here (Florida Speed Shop, if I remember right, but others are probably equally good).
I am signed up for Thursday 8/25 at Sonoma too, but had to ask for a raincheck/credit because I burned up my front tires and brakes at Thunderhill on Friday.
I suggest you start off in Sport 1 at Sonoma until you've had a few laps and are familiar with the course, there's a lot of walls and having the active handling on will help you dial in your entry speeds to turns and where to mash the fun pedal on turn exits (if the warning appears you went in too hot or hit the gas too soon).
How much will over inflated tires hurt 0 to 60 and launching? What is a good rear tire pressure for a C7 Z51 A8 for launching and still goos for the street? Thanks.
