LMR CAI and Katech ported throttle body
finished up the install tonight of the cai and throttle body. I will say you can feel a slight bump in power and seems to idle a bit smoother. also spins the tires easier. only real issue I ran into is the pcv hoses do not line up with the new intake pipe. had a friend take a look ,and suggested to flip flop the hoses from each side. also slight bending of the hoses is required. overall I'm satisfied with the performance gain for a couple of simple bolt on modifications.
Mission Accomplished
