Let's talk C7 spring rates
https://www.corvetteforum.com/forums...post1592998290
Assumptions:
- I assumed stiffer rates are for GS/Z06 are Z07 package, and FE3 on Z51 on the table.
- Assumed the stab bar referred to is front sway bar (Stingray doesn't have rear bar anyway).
- I assumed spring rates for base, Z51 and Z06 did not change for 2017.
Remarks:
- The spring rates between Stingray and Z51 are almost identical! Looks like the difference in comfort is mostly from sway bars (or lack thereof at the rear).
- As was also reported by the drivers, Z51 w/MRC spring rates are very low relative to the other models. What is interesting is that the regular Z06/GS rates are not that low, yet some regular Z06 forum members reported it as very soft, too. Perhaps the MRC tuning has more range and less compression for better comfort in non-sporty modes, or stickier wide-body tires may cause more lean.
- Except Z06/Z07, the front/rear ratio all over the place across the board. This is very confusing to me.
- The F/R ratio is
- 0.56 on FE3,
- 0.62 on FE4
- 0.80 on GS
- 0.66 on GS w/Z07 (is table missing front spring info???)
- 0.80 on Z06
- 1.07 on Z06 /Z07
- GS with Z07 is confusing. Sure, it will be a bit lighter up front, but should be less than 100lbs difference in total car weight. Is the chart missing the front spring rate for GS w/Z07? Another theory is that GM needed something softer than Z06 w/Z07's 190, but stiffer than 117, but we all know they hate new part numbers, so they fixed it up by using much thicker front sway bar at 32mm diameter, and 5mm thickness.
In summary, questions:
- Does GS w/Z07 really come with 117 front springs, remedied by a much-stiffer sway bar? Or did they just miss the additional spring rate in that table, to be used by Z07 option. I first thought for sure they must be missing the data on the chart, but then realized the sway bar is much stiffer.
- Instead of getting coilovers, perhaps one could buy the Z06 w/Z07 springs, and just buy shock bodies with no coil over them, so the additional stress on shock mounts would be eliminated? I was told this scenario allows cross-talk of the OEM springs, but I'm not sure how big of an issue it is. Until a vendor tunes their shocks specifically for this, though, this would be hard to do.
My guess is that 90% of Z06 buyers will never drive their car on the track, but will drive the car to the coffee shop and brag to their buddies that it will break 7 minutes on the 'Ring... and then complain that it hurts their back.
Rule 1) The grip of the tires sets the spring rate
Rule 2) the spring rate sets the damping of the shocks
Rule 3) Sway bars are used to fine tune the cars balance
For anyone that needs shocks for these springs on the other cars, just call the Bilstien tech center, they can re-valve the z51 non mag shocks with these spring rates...Last time I had this done( on another car) it was $75-100 bucks a shock.
To elaborate on my comment re: too high rear spring rate, if the effective wheel spring rate is indeed higher at the rear than front, you don't see this happening unless the car is rear-biased in terms of weight, like a mid-engine car (Lotus Elise, Cayman, etc.) or 911. Due to this, I still assume the leverage of the spring is lower than the actual spring rate suggests (it's pushing down on the control arm from the middle of it, not from the edge of it, losing leverage), and perhaps front springs have more leverage, changing the balance of (effective) spring rates.
An earlier "Ask Tadge" post indicated that there are different spring rates for Z06's without Z07 (FE 6 suspension) and Z06's with Z07 (FE 7 suspension). The same is likely true for GS's without Z07, GS's with Z07, Stingrays without MRC (FE1 suspension), Stingrays with MRC (FE2 suspension), Z51's without MRC (FE3 suspension) and Z51's with MRC (FE4 suspension).
https://www.corvetteforum.com/forums...fferences.html
How many pound/inch in 1 N/mm? The answer is 5.71014716277. So If you take 92.4 N/mm X 5.71 = 527.6 lb/in is the spring rate on the front of the z51 without mag ride....sorry, I am a old guy that thinks in pounds per inch....
That is not a lot of spring rate for a car of this weight and tire size....the question is...What are motion ratios are for the front and rear suspensions at the spring mounting points and the shock mounting points?
Has anyone gotten a corner weight numbers for a Z51 and alike?
Is there a curb weight per car listed some place? How much heavier is the lt2 than the lt1 ect....?
What is very confusing to me is that Z07 suspension comes with much much stiffer front springs, which makes the front stiffer than rear by about 7%, but every other setup comes with much softer fronts, where the rears are substantially stiffer in comparison. Considering how the weight distribution is almost identical among these cars, and how he suspension geometry is also identical, having different spring F/R ratio does not make sense. I would understand much stiffer springs, but a huge shift in ratio is hard to explain.
I can't explain or understand how an OEM arrives at such small differences between models, like we see here between the base and Z51, or GS and Z51. My racecar tuning experience tells me those differences are in the noise. You need very large spring rate changes to effectively change a car's overall capability or cornering balance, especially true when the bars are as big and with such short lever arms. If you look at the competitive cars in SP classes at autocrosses, for example, it's common to see cars with 2x - 4x the OEM front spring rates, and rear rates in the 1x - 2x range. That front Z07 spring is about 2x the Z51 spring, so swapping in just that front spring could really be the hot ticket.
-michael
I do have shock angles, distances from ball joints to spring pads and to shock mounts, and wheel weights for my Z51, but haven't gotten around to crunching numbers yet. For whatever it's worth, I think the car feels incredibly soft. The only harshness seems to come from high-speed compression damping on the shocks. For motions where low-speed damping is in play, the car feels like it wallows and bounces off the bumpstops. So I definitely agree with your "not a lot of spring rate" comment.
-michael
In short, I'd have expected F/R balance of Z51 to be similar to Z06, if not Z07, which is not the case.
On a side note, C6 spring rates are much different, and C6 T1 springs are much stiffer, and much more balanced front to rear. Considering the mounting points being very similar, it makes you wonder.
If you're looking specifically at cornering balance, even static wheel rates won't give you what you need to compare. I'm going to set up an example that illustrates this, but keep in mind I have no idea what the actual numbers are. We'd need to measure and calculate to know what differences exist front to rear.
Example:
Let's say the spring motion ratios are equal front and rear, and defined as y=0.5x. Let's additionally state the bars act on the same general area as the springs, making their motion ratio equivalent. Let's say the front bar rate is 500 and the rear bar rate is 400.
Z51 springs are 528/942, and the Z07 springs are 1084/1011.
Let's calculate what the effective wheel rate would be with high cornering loads, where the bar is in full effect:
Z51 front wheel rate = (500 * 0.5) + (528 * 0.5) = 514
Z51 rear wheel rate = (400 * 0.5) + (942 * 0.5) = 671
Using your F/R ratio comparison, this is 514/671 = 0.766
Z07 fwr = (500 * 0.5) + (1084 * 0.5) = 792
Z07 rwr = (400 * 0.5) + (1011 * 0.5) = 706
Using your F/R ratio comparison, this is 792/706 = 1.122
They are different ratios than what you calculated from the spring rates. They also do not compare to each other the same way.
1.07/0.56 = 1.91
1.122/0.766 = 1.46
There's too much bar effect to claim there's a linear wheel rate relationship with spring rates, when looking at what happens with cornering load.
Even GM doesn't bother with comparing ratios, nor with much in the way of precise rate calculation. They calculate ballpark figures, then use trial and error to zero in on what behavior they want. R&D is a huge part of every vehicle life cycle.
Also, doesn't the FE7 have the larger rear bar? That rate increase dwarfs the spring rates, and would make spring rates in the above calculations even less relevant.
All that said, again, I do think swapping in the front Z07 spring is probably a good thing. If I didn't race in a class where it's disallowed, I'd try it in a heartbeat.
-michael
I had incredible lean in corners with 315 NT01s up front and T1 shocks/sways (with FE3 springs). The tires moved up about 3", evidenced by the rub marks. If they did not gain so much dynamic camber, they would also destroy my fenders; I guess I'm lucky. I will get to try the very same set of tires with LG coilovers and sways. I will put a camera by the fender to watch the suspension movement with the new setup; I think it will be fun to watch : )
http://www.koni-na.com/en-US/NorthAm...s/C7-Corvette/
