I plan to buy the NX kit and run a conservative 50hp jet. Now what I was concerned with is im guessing the diablo tune I have advanced the timing. From what I understand advanced timing and nitrous don't go well. Should I be concerned?
I wouldn't advance the timing any more than the preset tunes already do anyway really.. timing is already jacked up pretty good compared to stock.. and I usually have to lower it a bit in my custom tunes to reduce/eliminate knock retard people have at WOT..
so I would just keep the timing settings as they are with the preset tune, don't raise it higher.. and then you'll need to actually lower the timing by -2 to -3 degrees for a 50hp wet shot..
I do not have the ability to change the timing because I am not a tuner. My car is stock besides a handheld Diablo tuner which I uploaded a program that's pre set. I'm guessing the diablo tune advanced the timing. I should contact them to find out at what degree they set the timing and then re search if its safe. Thank you for the help. Im a newbie at this.
Yes, as Lew mentioned, the devices we offer allow you to adjust timing at WOT in 3 RPM ranges, I'd recommend pulling a little bit for use with that 50 shot.
BTW, N2O is like crack. That 50 shot will simply leave you fiending for more
