PDR wont read disk any longer
Old Oct 22, 2016 | 08:44 PM
Greyeagle's Avatar
Greyeagle
1st Gear
Default PDR wont read disk any longer
I used my SD disk at Spring Mountain last week and now my PDR says that there is no disk inserted. I can plug the disk into my laptop and it works fine but will not load in the car. Any ideas?
Old Oct 23, 2016 | 01:05 AM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
Try reformatting it.
Old Jun 25, 2017 | 03:57 PM
Sam Mackay's Avatar
Sam Mackay
5th Gear
Default Reeformate SD Card
How do you reeformate a SD Card
Old Jun 25, 2017 | 07:35 PM
davepl's Avatar
davepl
Insert SD card in computer.
Go to "My Computer"
Right-click on SD card.
Pick Format...
If the disc is over 32G, it's different. Use forum search.
Old Jun 25, 2017 | 11:02 PM
MCK_Z06's Avatar
MCK_Z06
See of your card has a little slider on the side that says "lock" or "write protect". If its write protected it will prevent the PDR from reading the card and display the "no disc" message.
Your computer will still be able to read the data in this situation, the PDR will not.
Old Jun 26, 2017 | 09:27 AM
thebishman's Avatar
thebishman
Just eject it and reinsert. Should work fine.
To PDR wont read disk any longer
