For the life of me I cannot figure out how to install these. How are you guys accessing all the nuts? Especially on the passenger side. Extremely frustrated.
I understand that after the nuts are removed, you need to raise the engine in order to remove the pipes. Where are the motor mounts that need to be loosened? Man I wish I had a step by step guide.
It’s tight, but can be done without undoing the motor mounts. It’s been several years, but I think if I remember right that I just put a jack with a block of wood under the side of the engine I was working on and that gave me enough room.
for the life of me i cannot figure out how to install these. How are you guys accessing all the nuts? Especially on the passenger side. Extremely frustrated.
I understand that after the nuts are removed, you need to raise the engine in order to remove the pipes. Where are the motor mounts that need to be loosened? Man i wish i had a step by step guide.
What are install instructions if I already have a Borla X Pipe that I will be keeping? Do I still need to remove it or will the stock cats still drop down?
I don’t see these on the site... in the exhaust section. How can get a set of these? And do we have a link to the exact O2 extension bungs we need to get this to work without a CEL?
each order on the cat deletes i go case by case with customer. I send a paypal bill to your email for 739 and then after you pay ship em out to you.
So The Big Daddy O2 90-degree extensions go on the rear O2 sensors correct? with these installed will it prevent the car from going into COT without messing with the tune?
