Got those codes after my ECS supercharger install. I know they are barametric pressure codes but is this a hardware failure or just a tuning issue? Thanks.
Also my remote start doesn't work now. Is that in the tune too? Thought that was kinda weird. Just got the car back last night so Im trying to get educated on all this before I go back and have them tweak some things.
I had the breakout kit installed by my shop and all was good for a couple days but the p2227 came back again.After installing the breakout kit does the cars tune have to be adjusted again? If so in what way? Thanks.
Cel on ? Remote start does not work when the cel is on.
Yea cell is on. had the code after SC install then added the breakout kit and it went away for a couple days but is now back. Just wondering if the car has to be retuned after install of breakout kit?
I'm getting codes P2227 and P2229 after Procharger install and tune. Tune was done with LS9 map sensor so did the tuner just f up not disabling these? One of these showed as "pending fault" can't remember which one but didn't light up the CEL. I just installed a MMS wild catch can and these CELs lit up my check engine after some trial runs through 3rd and part of 4th gear under boost.
Using torque pro app to read and just cleared these for now CEL is off.
