Trunk does not open
Old Jan 5, 2017 | 08:21 PM
2k07z06's Avatar
2k07z06
Default Trunk does not open
Just had a dead battery and now the fob will not open the trunk. After jumping it the display told me the trunk was not closed even though it was closed. I now have to manually open it with the key.
Warranty expired 12/13/16 so no warranty any suggestions before I take it to the dealer next week?
Old Jan 5, 2017 | 09:24 PM
BELVIN20's Avatar
BELVIN20
Disconnect battery for about 10 minutes (negative cable), reconnect & let computers reboot, most likely will do the trick. I would also suggest a new battery, the C7 does not like low battery voltages.
Old Jan 6, 2017 | 01:14 PM
2k07z06's Avatar
2k07z06
Default trunk
Worked like a charm, thanks for the help.!
Do you know how hard it is to change out the battery myself?
Concerned with the little board positive hooks up to and any other issues might run into?
Old Jan 6, 2017 | 01:26 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
One of the forum guys made a "How To:" see this: http://netwelding.com/Battery_Issues.pdf
Elmer
Old Jan 6, 2017 | 02:45 PM
2k07z06's Avatar
2k07z06
Default Trunk/Battery
Elmer
Great link easy to understand, thanks Buddy I appreciate it!
Old Jan 6, 2017 | 02:47 PM
BELVIN20's Avatar
BELVIN20
Battery change out is not easy, GM stuck the battery in down low with no handle. The instructions in the prior post is spot on for the job, just take your time.
To Trunk does not open
