I have a friend changing the front brake pads on his 2015 Z06, and I can't find the torque specs for the two main caliper bolts along with the bridge bolt; and yes I searched! lol
Can anyone share them asap? Rears too if you have them. This for the irons btw.
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
St. Jude Donor '08
TIA,
Bish
Here ya go....
Fastener Tightening Specifications
Brake Caliper Bleeder - J56 Front
13-15 lb ft
Brake Caliper Bleeder - J56 Rear
106 lb in-12 lb ft
Brake Caliper Bleeder - J57 Front and Rear
13-15 lb ft
Brake Caliper Bolt - Front
162 lb ft
Brake Caliper Bolt - Rear
89 lb ft
Brake Caliper Bridge Pin Bolt
22 lb ft
Brake Hose Fitting Bolt
30 lb ft
Brake Rotor Bolt
106 lb in
Front Brake Shield Bolt
89 lb in
The above math is in correct. 12 lb-ft is 144 lb-in
Originally Posted by goec2468
Has anyone used the torque setting for the bolts of front calipers yet?
162 lb ft seems so high, I am afraid to snap the bolt off.
Thanks.
Regards
Götz
I'd go by the fastener size. There are several fastener torque calculators on the web, if you know the size, material and threads.
Most reputable race shops go by size and type of fasteners. They don't have access to every manufacturers service manual to search for the listed torque values that mfr lists. Sometime the listed torque value is more than the fasteners torque allowable capacity.
You actually don't need to remove the calipers from the hub assembly to change the pads, only remove them if you are removing the rotors as well. You can just slip the new pads in by sliding out the retainer pins and spring, and sliding out the old ones.
I wouldn't remove the caliper bolts unless you need to change or remove the rotor, since they require the dry thread locker on them when replaced (I just bought the new bolts for a couple bucks a piece that already have the thread lock applied, and replaced the old ones).
I changed my pads with about 2600 miles on the car and the OEM pads had worn down enough that it was very tight getting in the slightly smaller Carbotech 1521s. So the more you run the OEM pads the more likely you will need a spreader to move the caliper pistons back some to install the new pads.
