***Header DIY instruction help***
Old Jan 22, 2017 | 08:47 AM
2scary's Avatar
2scary
Default ***Header DIY instruction help***
Does ANYONE have a set of instructions for Stainless Works header install. It's looking a lot like I may need to drop the subframe, and I'm concerned about this.
Old Jan 22, 2017 | 09:06 AM
Silverboost's Avatar
Silverboost
http://www.corvetteforum.com/forums/...checklist.html
This is a thread I started a while back when I put my headers on. They were not stainless works but the process should be the same. You should not have to drop the sub frame.
Old Jan 22, 2017 | 09:14 AM
2scary's Avatar
2scary
Didn't have much trouble getting the stock items out, but I've worked with getting the headers UP from underneath and I really think I've exhausted every path and angle.
Old Jan 22, 2017 | 01:43 PM
2scary's Avatar
2scary
Help please....she's up in the air now. I see the Pfadt instructions call for unbolting the subframe, etc. really don't want to go that route if I don't have to.
Old Jan 22, 2017 | 04:54 PM
Silverboost
Is it the passenger side you are having trouble with? I had to unbolt the starter and remove the dry sump oil lines (if you have a z51) to get the passenger one in.
Old Jan 22, 2017 | 06:18 PM
2scary's Avatar
2scary
Just took the starter off and to my amazement, worked perfectly! Wish I'd have gotten this response earlier, but thank you. You are correct.
To ***Header DIY instruction help***
