Making Progress on Mike's F1X C7
Old Feb 15, 2017 | 04:01 PM
Billy@MTI's Avatar
0Billy@MTI
Former Vendor
Default Making Progress on Mike's F1X C7
Should have it all up and running with our port injection in about a week.
Old Feb 15, 2017 | 09:19 PM
Drew27's Avatar
Drew27
More pics........
Procharge makes a intake for it which will get intake away from fan hot air sucking straight in procharger....
How much did fan kit help?
Old Feb 16, 2017 | 10:01 AM
Billy@MTI's Avatar
0Billy@MTI
Former Vendor
What other pics would you like?
No they do not.
Not sure this is the first on we have tired.
Originally Posted by Drew27
More pics........
Old Feb 16, 2017 | 10:07 AM
agapsdiver's Avatar
agapsdiver
What's with the thin front tire???
Old Feb 16, 2017 | 10:43 AM
djnice's Avatar
djnice
Has port injection been done before on the LT1? What heads get used?
Old Feb 16, 2017 | 10:45 AM
Billy@MTI's Avatar
0Billy@MTI
Former Vendor
Its a drag tire.
Old Feb 16, 2017 | 10:46 AM
Billy@MTI's Avatar
0Billy@MTI
Former Vendor
I think one other shop did one. LT1 castings and TSP worked them.
Old Feb 16, 2017 | 05:05 PM
Drew27's Avatar
Drew27
No they do not.
Heres my Rotofab intake from procharger on my F1x
Old Feb 16, 2017 | 07:39 PM
bigsapper's Avatar
bigsapper
So one of the things I'm curious about with supplemental fuel injection is this.
The use of DI is fundamentally what allows the use of pump gas with static CR of 11-11.5:1. What does flowing fuel into the intake port require with regard to timing adjustments and fuel (octane) requirements?
Old Feb 17, 2017 | 09:46 AM
C7&7's Avatar
C7&7
Well you're effectively doubling the duel supply to the cylinder. So it really is just a way to run additional fuel and avoid adding meth injection.
It's another way to be able to run full e85 also.
However keep in mind a secondary port injection setup takes a completely separate pump (you have to sump the gas tank) and a completely separate ECU to run it.
More fuel supply / volume = ability to run higher octane = more power
Old Feb 17, 2017 | 06:12 PM
Billy@MTI's Avatar
0Billy@MTI
Former Vendor
Looks GREAT!!! Is that a intake they offer?
To Making Progress on Mike's F1X C7
