Right rear cooler
Old Mar 22, 2017 | 08:09 PM
Ninja2016's Avatar
Ninja2016
Default Right rear cooler
Can anyone tell me what this cooler is for behind the right rear wheel under quarter panel?
2016 Z06
thanks
Old Mar 22, 2017 | 09:30 PM
RonC7's Avatar
RonC7
Right rear cooler is for the ediff. Left rear cooler is for the transmission.
Ron
Old Mar 22, 2017 | 09:40 PM
X25's Avatar
X25
Sr.Random input generator
Ron
+1.
Old Mar 24, 2017 | 01:14 PM
Ninja2016's Avatar
Ninja2016
Ron
Ron or anyone....Have y'all changed the oil in the C7 Z06 eDiff?
and if so is there a video or a procedure of how to?
all I can find is for the C6 Z06 eDiff....and the dealership told me it's different from the C7 Z06..Procedure
Old Mar 24, 2017 | 02:15 PM
NSC5's Avatar
NSC5
Ninja, It is part of the sticky area of the tech forum and make sure to stay away from the separate hydraulic circuit that is part of the ediff control system or you will have a lot more work. The hydraulic instructions are immediately following the diff fluid in the linked part of this section: https://www.corvetteforum.com/forums...ice-specs.html
You car does need to be raised and level to properly drain/fill the system.
To Right rear cooler
