How to make C7 startup louder?
Old Apr 17, 2017 | 06:25 PM
bizkd1's Avatar
bizkd1
2nd Gear
Default How to make C7 startup louder?
I have a 2016 corvette with the chevy performance exhaust. And it is loud but my friend just got the 2017 camaro ss zl1 and when it turns on, it revs higher on startup. Are car shops able to go into the computer to change the settings on how much the car revs at startup? Or is there anything specific that I should tell them?
Thank you!
Old Apr 17, 2017 | 06:38 PM
T/A KID's Avatar
T/A KID
Increase base airflow on startup/increased RPM.. increase the low timing values on startup RPM... that alone will give it some bark on startup
Old Apr 17, 2017 | 06:40 PM
bizkd1's Avatar
bizkd1
2nd Gear
A shop can do this? And would it be expensive or is that just in the computer settings?
Old Apr 17, 2017 | 08:32 PM
T/A KID's Avatar
T/A KID
Its in the settings!!! Anyone competent in programming could, but good luck on that, most gen 5 programs I look at are wrong
Old Apr 19, 2017 | 03:16 PM
Kent1999's Avatar
Kent1999
Since you're new here, and have a 2016 that is presumably still under warranty --- you should also be aware that changing the engine programming as stated above will end up blocking (aka, "voiding") the powertrain portion of your factory warranty. And yes, GM can tell if you've modded the computer and then "un-modded" it back to stock.
Old Apr 19, 2017 | 04:53 PM
NSC5's Avatar
NSC5
Which model 2016 do you have? The ZL1 uses the 650 HP LT4 like the Z06 which is louder than the base model LT1 engine. They are loudest at cold start because of the need to meet cold start emissions by quickly getting the cats hot so it is running rich at that point.
I try to remember to set my Z06 exhaust back to tour when traveling to avoid being obnoxious when cold starting it at a hotel in the morning. I forgot one morning last year in Townsend TN and a Harley rider laughed and said his bike just pissed itself when my Z started up next to it.
And I agree with those who warned you about tuning the engine for this since it will void your powertrain warranty potentially making that increased loudness VERY expensive if something goes wrong during warranty.
Old Apr 19, 2017 | 10:03 PM
NinjamanZ51's Avatar
NinjamanZ51
2017 C7 of Year Finalist
Warranty? Pshh...
Old Apr 24, 2017 | 07:54 AM
BAblackvette's Avatar
BAblackvette
Corsa X pipe on mine made cold starts brutal. Other then that, not really louder.
Old Apr 24, 2017 | 08:27 AM
xxaarraa's Avatar
xxaarraa
Borla x-pipe makes startups noticeably louder. Has a nice sharp bark to it now.
Old Apr 24, 2017 | 08:28 AM
dbaker's Avatar
dbaker
Just pull the NPP fuse.
Open at startup and all the time.
\db2
Old Apr 24, 2017 | 02:54 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Park the car under an overpass?? sorry I had to..
Old Apr 24, 2017 | 04:52 PM
C7&7's Avatar
C7&7
I have to ask if you are starting the car in sport mode or in touring? Keep the car in sport mode and the flaps will be open when you start it. Or like mentioned above pull the fuse and they will always be open.
Old Apr 24, 2017 | 05:52 PM
NSC5's Avatar
NSC5
I usually leave mine in track mode but the really loud start only occurs when cold which is what I think the OP is wanting all of the time.
Old Apr 24, 2017 | 06:01 PM
C7&7's Avatar
C7&7
Well if you park it in track mode then it changes to touring for the next start. In touring the flaps are closed. This is how my 2014 operates anyhow.
Old Apr 24, 2017 | 06:30 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
As NSC5 pointed out earlier, the reason the car sounds like that is because it's dumping excess fuel into the combustion chamber to make the car run rich in order to warm up the cats. Simply put, the car is not designed to sound like this for more than about 30 seconds after start up. If you really want to sound close to that, put 2" long tube headers on it with no cats and a big lumpy cam. That'll get you there..
Old Apr 24, 2017 | 08:27 PM
NSC5's Avatar
NSC5
Sorry, to clarify I meant the exhaust (engine sound management) is set to track mode. I have exhaust mode and steering unlinked from driver mode so the exhaust stays in track and the steering stays in sport regardless of driver mode setting. Mine is a 2016 and I think for 2014 you would set engine sound management to off which has the same effect as setting the 2016 sound management to track.
Old Apr 24, 2017 | 08:36 PM
Z06NJ's Avatar
Z06NJ
I notice when I keep my foot pressed about 5 or 10% part throttle when starting the car (and after it starts for 2 seconds), it is so freaking loud!!!
To How to make C7 startup louder?
Old Apr 25, 2017 | 08:59 PM
pkincy's Avatar
pkincy
Whatever happened to Teddy Roosevelt's attitude? Speak softly and carry a big stick.
Old Apr 26, 2017 | 02:55 PM
VictorBarron's Avatar
VictorBarron
The louder the better at start up. Obnoxious loud is good!!
Old Apr 26, 2017 | 03:21 PM
thrilled's Avatar
thrilled
B&B mufflers.Headers.When you start press your foot down on the gas petal.Guarantee your
Neighbors won't be happy about it.
