OEM Airfilter mod
Old Apr 19, 2017 | 06:32 PM
blackc7z51's Avatar
blackc7z51
Cruising
Default OEM Airfilter mod
Hi guys,
First of all english is not my mother tongue so please excuse any errors on my part.
I didn´t want to spend a lot of money on a so called CAI with questionable performance gains and expectable lesser air filtration. So i came up with the idea to "enhance the airflow" of the original Airfilter
by getting rid of the plastic cage in it. I cut it lose at the upper end and then could take the rest of it in almost one piece out. The filter itself still seems as stable as before.
Looking forward reading your comments
Greetings from germany
Old Apr 19, 2017 | 06:43 PM
davepl's Avatar
davepl
I don't think the cage amounts to a flow restriction. The seal might, as does the paper. I'd recommend a "Green Filter", which I understand to be reasonable common/popular over in Europe.
If the paper becomes restrictive with age there's a chance your filter could collapse. Imagine that there are 100" of surface area, and you get a 2psi differential drop across the paper. That's 200lbs of crush force, which I'd guess is the reason they have that cage in there in the first place (though I do not know for sure).
Old Apr 19, 2017 | 07:04 PM
rebel502's Avatar
rebel502
At high flow rates, I suspect the paper elements will collapse together essentially ending or severely restricting air flow. The plastic cage was most likely put into the design to keep that from happening.
REBel
2017 Stingray Z51/3LT Corvette Racing Yellow/Black (Awaiting Delivery)
1992 ZR-1 Yellow/Black #031
Old Apr 19, 2017 | 07:05 PM
8SPD Z51's Avatar
8SPD Z51
Default OEM Airfilter Mod
Without the plastic bracing I think the paper filter could be prone to collapsing. It's there for a reason.
Old Apr 20, 2017 | 06:28 AM
goec2468's Avatar
goec2468
I fully agree to the comments being made.
K&N as well as green filters are available in Europe for our Corvettes and if you want to gain a couple of horses with little money, that is the way to go.
Anything else will cost much more (in particular in Europe) and will not be legal in most cases and void your guarantee.
When the guarantee expires, I will most likely add a supercharger, that is a real performance gain, but also costs serious money.
Regards
Götz
Old Apr 21, 2017 | 09:47 AM
blackc7z51's Avatar
blackc7z51
Cruising
Thank you for your feedback. At least nobody complained about my english
But think about that- if only this plastic cage is preventing the airfilter to collapse under "full throttle" the filter (same used in the Z06?) would be very very restrictive.
By the way the plastic seemed almost brittle and likely fell apart by looking at it
Never the less i´ll try to take a testdrive on the autobahn at the weekend to see if there is a performance loss because a lack of air and have a look at the filter if there are any marks of deformation.
Old Apr 21, 2017 | 10:28 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Your English is better than half the people on this forum
Old Apr 23, 2017 | 10:06 AM
Larry/car's Avatar
Larry/car
GM seems to have optimized air filter performance, no gain replacing the OEM unit.
Old Apr 23, 2017 | 06:36 PM
goec2468's Avatar
goec2468
A car magazin tested a high flow air filter element vs the original filter, the gain was 9 or 10 hp.
Not much, but it comes cheap.
Regards
Götz
P.S.: Where in Germany are you based?
Old Apr 26, 2017 | 06:50 PM
z edge's Avatar
z edge
To OEM Airfilter mod
