Oil Change Sensor
Old Apr 27, 2017 | 02:29 PM
sbuck863's Avatar
sbuck863
Default Oil Change Sensor
Does the oil change sensor actually monitor the contamination level of the oil, or is it just a simple mileage-based reminder? I use Mobil 1 full synthetic, which should be good for at least 10,000 miles, but the sensor is telling me that I need an oil change after only 6,000 miles.
Old Apr 27, 2017 | 02:35 PM
BEZ06's Avatar
BEZ06
You're probably getting a reminder because it's been 1 year since your last oil change.
To my knowledge there's no sensor that monitors the condition of the oil.
However, the Oil Life Monitor does take into account how hard you drive the car, mileage, and length of time since the last oil change - and as I mentioned above it will zero out and tell you that an oil change is needed after 1 year, even if you have hardly driven the car.
From the Owner's Manual:
Engine Oil Life System
When to Change Engine Oil
This vehicle has a computer that
indicates when to change the
engine oil and filter. This is based
on a combination of factors which
include engine revolutions, engine
temperature, and miles driven.
Based on driving conditions, the
mileage at which an oil change is
indicated can vary considerably. For
the oil life system to work properly,
the system must be reset every time
the oil is changed.
It is possible that, if driving under
the best conditions, the oil life
system may not indicate that an oil
change is necessary for up to a
year
. The engine oil and filter must
be changed at least once a year
and, at this time, the system must
be reset.
