Engine coolant loss
Old May 7, 2017 | 08:39 PM
Jet Vet's Avatar
Jet Vet
St. Jude Donor '15-'16
Default Engine coolant loss
I'm having engine coolant loss during track sessions. There is no obvious leak anywhere in the system, and no indication of water in the oil. I suspect a bad thermostat and resulting coolant loss out of the overflow line from the coolant reservoir. This would only show up at high temps on the track and there would be no leakage showing back in the pits, only low coolant level, which is what I have.
I can't find the overflow line from the plastic reservoir tank on the passenger side firewall. Is anyone familiar with that tank and the coolant system, and can tell me where the overflow line is located? I want to test my theory by attaching an empty bottle to the end of that line and running the engine hard. Thanks
JV
Old May 7, 2017 | 09:45 PM
Bill Dearborn's Avatar
Bill Dearborn
You could have a small coolant leak in the head gasket or the intake manifold. Have you checked the underside of the water pump to see if the pulley and the bottom of the pump feel sticky. My C6Z had a slight leak from the water pump that didn't show up over night. It took 24 hours before it would drop a few drops of coolant. I was literally working on the car getting for a track event and took a lunch break. When I came back to the car a half hour later there was a small puddle of coolant under the car that wasn't there before I went to lunch. That was right around 24 hours after I had parked the car in the gareage. Once the dealer replaced the water pump the sticky feeling under the pump and the back side of the pulley was gone.
Bill
Old May 7, 2017 | 10:42 PM
Jet Vet's Avatar
Jet Vet
Bill
Thanks Bill, No sign of any leak or seepage under the pump. The loss is quite significant, in a 20 minute session of very hard driving it will lose almost a half gallon. If it were a head gasket, I would expect to see evidence in the oil from that much coolant loss.
JV
Old May 10, 2017 | 04:17 PM
Bill Dearborn
JV
A leaky head gasket may not put coolant into the oil. We had a car that had a leak that showed up as the engine cooled and coolant would get sucked into the cylinder. One day when we went to start the engine it was hydrolocked. When I pulled the spark plugs to try and figure out why the starter couldn't crank the engine I got a large amount of coolant flowing out of one spark plug hole.
It could easily be pumped right out the exhaust. If you are losing that much a head gasket leak should leave a cloud of white smoke behind the car. It would tend to shorten the cat life significantly as well.
Use a cooling system pressure tester to check for pressure drops when the car is cold and when it is hot.
Bill
Old May 11, 2017 | 12:42 AM
Jet Vet's Avatar
Jet Vet
Bill
Thanks Bill, we did just that at the dealership this morning, and under pressure found a leak in a water line connection at the block which had worked loose.
JV
To Engine coolant loss
